I'm having problems with guide coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2007, 09:37 AM
Ripped's Avatar
Last journal entry: First RoadCourse Video
Everything was going okay, when I was using guide coat with heavier grits. I am having problems now with it clogging the 100 grit.
Possibly I am using the wrong type, using too much, or using it at the wrong time.
When I am filling each night now. I lay down my skim coat, and let it harden overnight (it sands better if it's a little harder.) I also usually spray on the guide coat just after I lay down the filler, maybe I should wait until the filler is hard.
Anyway last night I wasted and clogged up so much sandpaper, it was very frustrating. Finally I used laquer thinner to remove the guide coat. That was better.
What am I doing wrong, or what can I be doing better to make this work?
Old 02-28-2007, 10:00 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Are you completely covering it like a paint coat?
It sounds like you're using way to much.
But I don't know what you're using either.
I usually just mist a coat on with a lacquer "sandable" primer
out of a rattle can. It's no more than a bunch of little specs
after spraying, nowhere near hideing coverage.
But that's all I ever need.
I can't see how that primer could ever clog paper.
Maybe you're using an enamel? It could do that
Old 02-28-2007, 11:12 AM
Ripped's Avatar
I'm using an actual guide coat in a spray bomb, I'll have to check the brand name.
Old 02-28-2007, 12:27 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Are you guide coating body filler or spott putty coats? This is not recommended or needed.
Guide coats should only be used in primer coats for block sanding and should not be used heavily.
This is just the way I was taught in the old days and I still carry it forward...
Old 02-28-2007, 01:11 PM
You can guidecoat anything, metal, fillers, primers, old paint-just dust on a thin dry transparent coat. Or use the dry guidcoat.
Old 02-28-2007, 02:53 PM
Ripped's Avatar
I picked up some sem guide coat, hope that will be better, also
Old 02-28-2007, 10:37 PM
302 Z28's Avatar
SEM guide coat is great stuff. If you use a cheap rattle can paint and use way too much you will get the clogging. All it takes is a very light mist coat, just enough to show the low and high spots. It does not need to completely cover the area.
Vince
Old 03-01-2007, 05:08 PM
adtkart@aol.com
Ripped.... Consider what a guide coat is for. Quite simply, it is so that when you drag a piece of sandpaper attached to a sanding block across a surface, it will come off, showing where the contact was. That will show high and low spots. It is not for filling or covering anything. If you wanted to "guide coat" over black primer, for instance, you could actually do the same thing by throwing a handfull of bondo dust at the surface, although it would not stick as well.
If you apply it lightly, as said above, you should not have any problems with the "guide coat" clogging the paper.
Aaron
More SBC problems. FASTCHEVY Engine 8 03-08-2006 04:04 PM
Base Coat problems RyanB Body - Exterior 4 02-20-2006 04:50 PM
body line cole5_0 Body - Exterior 13 10-14-2005 04:57 AM
laminating- gel coat pre-release powderbill Body - Exterior 5 06-12-2005 06:59 PM
PPG Omni BC/CC Buffing Problems casadejohnson Body - Exterior 17 12-23-2003 07:53 AM
