It was a 2-wheel alignment.I'll check the steering column, for straitness.
ds rave the only thing in the front that wasn't changed was the original crossmember still remains.Wheel bearings are adjusted right.
Rear leaf u-bolts will be checked today for tightness.Wheelbase centers will be checked today[one side then the other]
No dog tracking evident.There is an awful tight spot in the center,of the steering, this occurs when its up on blocks[suspension hanging loose]. it loosens up as it approachs either end..And kar not running[power steering].The steering box adjust; shows a slight[inch maybe] of play when turning.from left to right.
And when i find the problem i will.......!definitely!!!! let you all know whats going on and what it was. I will do these next ideas today, then i'll get pictures if they fail[hard to get good shots under the kar.]
cheers bob s
. cobalt 327----------sorry i missed your point!
