im having wiring problems with an engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2007, 02:53 PM
Last journal entry: Well, about that mustang...
hey guys, i have a 97 ford ranger that had a 2.3L and its getting a 94 ford rangers 2.3L... the problem is the sensors are different and they are built into the block.... the 94 doesnt have these... so needless to say i got huge problems...any help would be appreciated
thx,
ntx
Old 03-04-2007, 04:58 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Are you Sure they are built into the Block?
I'm not a Ford guy at all, But I can't see where that would be possible, if you consider that sensors fail, and the vehicle must meet smog. Perhaps take another look, It may only appear they are not replaceable..
If not , do you still have access to the donor Truck, it's harness and Computer? You may have to swap those too.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-05-2007, 08:48 AM
I assume a 97 is subject to emissions testing in CT? If so, this swap is illegal. Depending on how good the inspector is, it may not pass the visual part of the inspection.
Rule of thumb is that it's legal to put a newer motor into an older car. You can always swap "cleaner" for "dirtier", but you can't go the other way. Now, having said that, if the two years were identical in equipment, there would be no problem. Since is sounds like they aren't, you have a problem.
Old 03-05-2007, 11:22 AM
the truck is in tx... and emissions for that swap isnt a problem
Old 03-05-2007, 11:29 AM
aka Duke of URL
I think what he is saying is that the 94 engine asm. does not have the provisions for some 97 engine sensor locations. Is this correct?
Old 03-06-2007, 09:04 PM
sensor locations are probably differant thats a couple years differance. ur best bet is to grab the engine wiring diagram for both and see what is what alldata is probably best for u.
also sometimes the sensors are in the correct spots but use differant style harnesses or perhaps flip wiring emissions is by far much differant for both those trucks. also if they repaired or replaced known faulty sensors from the almost 4 year differance. you may be better off just rebuilding ur old instead of fighting with it. i ran into that mistake a year ago i swapped motors on a 2000 escort with a 98 and everything was differant they went from a map to tps also some of the emissions provisions were differant has well has o2 sensor placement. remember next time just cause the body looks the same does not mean its engine or electrical is the same. every year they do a update from known faults and changing part manufacters and what the goverment requires for that year performance of the vechicle and gas mileage all play a role
id just go rebuild or buy that year motor itll be cheaper and faster rerouting wiring just to make it work could take weeks if u dont know what your doing btw ur ecu is probably differant
Old 03-06-2007, 10:53 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Are both engines dual plug engines? Distributorless ignition? (2 spark plugs on each cyl) I don't recall what years the changeover was. Seems like there was an 8 -10 year span for that engine model of the 2.3. The sensors are all removable. OBD I sensors have different mating connectors than OBD II. If the block and head are the same then all sensors must be moved to the older engine.
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
Engine Swap hustl3r Electrical 7 06-03-2006 12:28 AM
v6 Engine Swap millennium Engine 3 04-29-2004 02:50 PM
Engine Swap pete379 Engine 4 03-30-2004 07:22 AM
81 elcamino engine swap freeryde13 Engine 1 09-26-2003 03:27 PM
