-   -   im i crazy? (http://www.hotrodders.com/forum/im-i-crazy-209315.html)
hellfridge 11-25-2011 10:37 AM
im i crazy?
hey guys im just getting int the hole hotrodding/customizing thing and picked up a 79 olds custom cruiser to play with.
so last night i was running this idea
im pulling the motor out of a 76 blazer rebuild 40 000km ago but what if i swap out the motor tranny and have a transfer case in it and not install the front diff and drive shaft. that way i can have a low gearing for when i want to race and have a high ration for when im just cruisin . i know ill have to do some cutting on my floorboards to make it fit and thats not a huge deal to me.
im doing most of the car myself with the help of my brother inlaw so time to do this isnt an issue.
is the theory behind this right?
thanks
Glen
MARTINSR 11-25-2011 10:57 AM
First off the transfer case would go right there your passenger seat is, and mean RIGHT WHERE it is. I don't believe there would be room for the seat if you were to put the transfer case there.
I am thinking a 700R4 will do the same thing as you want with a lot less hassle.
One rule in my mind when making mods on a car, a house, whatever, don't do them JUST BECAUSE you have the stuff sitting there doing nothing. Build what makes sense.
Look at it this way, ask yourself this question before a modification like that. "Would I do this if I didn't have that transfer case?" If you only had that motor sitting there in your garage and were putting it in your Olds, would you go shopping for a transfer case and cut up your floor to put it in? If that IS something you would go out of your way to do, then do it. But don't do it just because you have that transfer case sitting there.
hellfridge 11-25-2011 11:02 AM
never thought of going to a 700r4 that might be a better idea
