I'm an idiot!! mixed reducer with hardener instead of clear!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2007, 07:25 PM
I grabbed a can of Nason base reducer instead of the clear (very similar can, should have read the label) and mixed it with hardener and sprayed it onto my undercarriage!!
I laid the base down (nason ful-base) and then topcoated it with a 3:1 ratio of reducer to hardener (no clear)!!!
What do i do now???
I still need to get a clear coat on it, but how long should I wait before i apply it? should I put another coat of base down first?
Help this idiot!!
Old 12-17-2007, 07:30 PM
31 five window
Last journal entry: grill and rear end
I would test sand and spray in a small incospicuouis place and see what happens.
Old 12-17-2007, 07:32 PM
31 five window
I guess i am an idiot too,I hit submit instead of spell check.
It's just barely passing it's flash time right now. Wouldn't it be too soon to sand?
I sprayed it probably 30 minutes ago. it is still glossy in some areas. Should I just allow extra time for the reducer to evaporate out and then shoot the clear?
Old 12-17-2007, 08:12 PM
Last journal entry: Suggestions worth sharing
If it was mine, I think I'd take rags and solvent, and try to wipe it off before it begins to moisture cure. Be careful if you try that though to make sure you wear good chemical resistant gloves so you don't get the hardner/solvent mixture on your skin.
Old 12-17-2007, 10:22 PM
Hehehehe he said "incospicuouis"
Just kidding, geez, if it wasn't for spell check or my living spell check (my wife) you guys wouldn't be able to read what I write!
You know, the first thing I think is that the base would have wicked the solvent and the hardener into it. It may have kicked the base and if you just sprayed clear over it, all would be good. But I am not sure, I sure as heck wouldn't want to tell you that. I could see trying it myself. But I would say the best idea is to wipe it off.
Old 12-18-2007, 07:58 AM
lets cut it up's Avatar
Try a small area to make sure you don't get a re-coat lift or any other reaction then just spray the clear over it. If any thing it will make the clear stick to the base better as the hardener and reducer should soak into the base. I put hardener in my base to make them "bond" as it is often recommended Dupont(they make nason ) when i spray base/clear. But the best thing would be to call the jobber and see what they say. They can call tech for you and get an sure anwser.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Clear coat reducer? magnoman Body - Exterior 8 07-01-2007 03:42 PM
Clear coat bumps solvent pop? magnoman Body - Exterior 9 05-14-2007 09:58 PM
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 05:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 02:52 PM
