Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I'm at an impass with my 347 build
Old 12-12-2012, 01:00 PM
engineczar's Avatar
engineczar engineczar is offline
Another option is to just switch out the oil rings from a cheaper set.
Usually low tension ring sets just refer to the oil rings and not the two compression rings. Oil rings generally come anywhere from ultra low 8# to more than 20# for stock stuff. Most off the shelf low tension sets are in the 15# range.
BSE Racing Engines
