I'm at an impass with my 347 build
I'll try to be concise here (HA!), but basically I think I've worked myself into a slightly expensive situation, and I just need some advice on getting out of it... as cheaply as possible.
I've got this 347 Ford stroker I'm building and I made some rather bad decisions when it came time to get the thing machined. You see, I ordered my bottom end kit from Coast High Performance, and along with their kit, they (unknown to me at the time) sent me a rather expensive set of low tension plasma-moly rings. According to my machinist, plasma-moly rings require a much finer finish on the cylinder bore in order to live, and so I followed his recommendation, which cost me a few extra bucks. Unfortunately, in a bout of absent-mindedness, I completely forgot to ask him to use a torque plate, and my machinist never asked (he told me later he does not typically recommend this for street applications like mine... but that's under normal circumstances.) My machinist never saw my rings before he did the bore/hone, so he didn't realize they were low tension... and a while after the work had already been done, I realized what they were, did a little research on them, and realized that low tension rings really need a perfectly round bore to work correctly. So, to sum it all up where I am at this point... I have cylinder bores that are honed specifically for these really expensive rings, but not torque plate honed, so they're not ideal. I'm worried I'm going to end up with an oil burner, especially with the already troublesome rod ratios of 347's. At this point I can buy new plasma-moly rings that are NOT low-tension, but they are kinda big bucks (something like $140). And I already spent extra on the machining, when, if I'd known, I could have bought a set of cheapo rings from the beginning and been done with it. But does it REALLY matter? I am adamant at this point that I cannot keep throwing away money on useless parts that don't help me at all. I've run way over budget doing that kinda thing, and all the little "oh but it's only 100 bucks more" REALLY adds up. Do I just run with what I have, or drop even more money on new rings? |
Now your motor came with low tension rings if its a 87 or newer. I think?? Just put it together with what you have it will be fine. If your machine shop has bored and honed the cylinder it should be fine. Since the engine was setup for the rings you have best to not run different rings. Since you have them run them it will be fine. the original engine would last 100K miles with those rings. The factory also does not do such a hot job of boring them and people do re ring them without much problems. |
Well, the block itself is of 1978 vintage, not that it really matters, with all that's being done to it.
And the rings are actually already gapped to be honest... I have been building this thing for a while now, and I was going to just run with em like you suggested, but I had second thoughts about it and came here to see if I was making a big mistake. I was unaware that any 302's came stock with low tension rings... that makes me feel a bit safer for sure. |
Another option is to just switch out the oil rings from a cheaper set.
Usually low tension ring sets just refer to the oil rings and not the two compression rings. Oil rings generally come anywhere from ultra low 8# to more than 20# for stock stuff. Most off the shelf low tension sets are in the 15# range.
BSE Racing Engines |
Thanks oldbogie, he actually did a fairly decent job on the cylinders themselves, and at the time I had access to some pretty accurate measurement tools at my school, where I affirmed that the forged pistons had around .003"-.004" clearance as was called for in the piston's instructions for my street application. Personally I do not trust ANY machinist to just "get it right" for me, and I checked and rechecked all the work that was done, and was fairly satisfied with the results, especially when I compared it to other machine work from other shops.
If the bores have already been smoothed over for his other rings wont the cast and moly ring combos not seat into the block right. Since they still need that first cut in to really seal up like factory. This was my first thought as well but wasnt sure it would last as lng as just running the rings he has and hope the machinest did a good job. @Engineczar i think its a ford 347 alot of builders use low tension compression rings as well. I know most chevy applications with low tension are only for oil ring but really not sure. Just had some issues with fords low tension rings and lots of blow by with big turbos. |
| First SBF build.. 347 | zildjian4life218 | Engine | 9 | 01-23-2012 03:14 PM |
| 347 | peteb | Engine | 0 | 10-02-2010 11:16 AM |
| 347 cam help | MUSTANGMIKE95 | Engine | 0 | 02-06-2009 10:30 PM |
| Is It Really a 347?? | lakecityg | Engine | 7 | 07-17-2003 05:18 PM |
| Ford 347 Build-Up | nightrain_rod | Hotrodders' Lounge | 4 | 06-23-2003 11:46 PM |
