Early Hemi rocker shafts Hotrodders.com Free Speech Parts Auctions
Bid on a part, or auction one off -- help us defend against a frivolous lawsuit, and protect free speech online.
Click here for details.
Parts currently up for auction: 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, Early Hemi rocker shafts, "Power Rods" billet air cleaner top.
Model A Ford headlights
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-26-2008, 11:13 AM
flyinv55's Avatar
flyinv55 flyinv55 is offline
I'm no bodyman, just havin some fun.
I've never tried bodywork but I have read alot about it and now I am experimenting on my '56 ford. I know that buying new fenders would be the quick and easy fix but again I am experimenting. Whatever happened to 'Glazing Putty'?? I cant find any anywhere.
Size:  72.5 KB  Click image for larger version
Size:  72.9 KB  Click image for larger version
Name:  56f100 fender3.jpg
Size:  110.4 KB  Click image for larger version
Size:  64.2 KB  Click image for larger version
Old 03-26-2008, 11:50 AM
Dragon J's Avatar
Dragon J Dragon J is offline
re: I'm no bodyman, just havin some fun.
Hey flyinv55- gone are the days of the old 'spot putties'- now you can use a two part polyester finishing putty which is more durable and compatible with today's finishes. Look at your local supply stores (I use Martin Senour paints at NAPA a lot) and they should clue you in on what you need
Old 03-26-2008, 06:56 PM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
Ask for a tube of "Icing" with activator.
Old 03-26-2008, 07:18 PM
HalfOunce HalfOunce is offline
Evercoat makes a good glazing putty as well. its 2 part non shrinking
Old 03-26-2008, 07:27 PM
Short Shift's Avatar
Short Shift Short Shift is offline
Icing is too thin. Get some platinum glaze. It sands nice and it is a little thicker than Icing. I always have a problem with Icing running right off the spreader before I get it to the panel I'm putting it on or having it run off the mixing board.
Old 03-27-2008, 06:15 AM
motomonkey motomonkey is offline
I have used Evercoat Metal Glaze with great results. I personally love evercoat products and their tech department is very friendly, I had used alot of their stuff but hadnt used the Metal to Metal so I called them about it and They actually sent me a free quart to try! Now thats customer service!!
Old 03-27-2008, 07:47 AM
MARTINSR MARTINSR is online now
Excellent work! "Glazing putty" was a lacquer primer in a tube (basically) and JUNK by todays standards. I have to agree with Evercoats products being top knotch. I have used all Evercoat fillers for years with trouble free service.
As far as a modern "Glazing Putty" again, Metal Glaze or Glaze Coat from Evercoat are my favs. They are the identical product but with a different color. The "Glaze Coat" is beige with a white hardener and probably hard to mix properly for the newbe, stick with "Metal Glaze" which is light blue with the blue hardener, much easier to see when it is mixed properly.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "I'm no bodyman, just havin some fun."
What percentage does an experienced bodyman make? rusty428cj Body - Exterior 19 02-02-2007 08:58 PM
Beater or hot rod, which is more fun? loyter Hotrodders' Lounge 5 06-27-2006 03:36 PM
Just havin fun in the garage jscj777 Introduce Yourself 2 01-02-2006 06:24 PM
Some girl is probably havin a fun night. 1Fast65Elky Hotrodders' Lounge 5 03-21-2005 02:55 PM
havin' fun now tony00 Hotrodders' Lounge 7 12-02-2004 09:51 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
