im stumped - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2011, 09:57 AM
im stumped
i took that carb apart and the primary fuel bowl is stuck to the metering block what should i do to get the bowl off of the block i have tapped it with a screw driver handle and no luck
Old 09-18-2011, 10:37 AM
T-bucket23's Avatar
Wiki Edits: 26
Try a razor blade, someone may have used sealer or form-a-gasket on it.
Chet
Old 09-18-2011, 11:05 AM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
i remember some years ago they used to make a (bucket) that had carb cleaner in it and you just set the body of the carb in it and let it sit over night and it would dissolve all the crap that was in there if they still make them that would seem to do the trick...
Old 09-19-2011, 08:28 PM
Thanks you two for the info.just wasn't for sure if prying on it with a screwdriver would damage the matting surfaces of meter block or float bowl.thanks again
Old 09-20-2011, 02:53 PM
helrazr3's Avatar
as a general rule with carbs the less prying the better. if you can let it soak a bit or spray it down with carb cleaner give it a few and see it that helps if not use a razor or utility knife blade to apply light pressure and try to separate the two
Old 09-20-2011, 04:17 PM
techinspector1's Avatar
Wiki Edits: 326
^^agree
Old 09-20-2011, 05:17 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
And then when you get it apart you get to scrape all the old gasket material off the block and bowl !!!
Help I'm Stumped grapro Engine 1 12-25-2008 01:45 PM
Stumped Need Help Meka Engine 0 08-08-2008 03:02 PM
ok...I'm stumped jrm123180 Engine 6 04-09-2007 08:56 PM
Need FI help. I am stumped so far! Siggy_Freud Engine 17 01-28-2005 07:22 AM
OK I'm stumped Kurt Suspension - Brakes - Steering 16 01-21-2005 10:48 PM
