Im sure this is a stupid question, but... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2006, 04:28 PM
Hey hotrodders, here's one:
I have rebuilt and engine and had the transmission rebuilt for a 76 Corvette 350. the transmission is a THM350 automatic. the engine starts no problem, but when i put the car into gear, nothing happens? is there supposed to be some connection between the brakes and the transmission that i have failed to connect that would not allow the transmission to change gears from park to anything else?
Old 11-08-2006, 04:47 PM
njbloodline666's Avatar
I Love VTec
i know this sounds silly, but did u bolt the flexplate to the torque converter. also, did you remember to put fluid in the transmission?
Old 11-08-2006, 07:46 PM
Wiki Edits: 49
Originally Posted by njbloodline666
........... did you remember to put fluid in the transmission?
This is a common error. Not only do you have to add fluid to the torque converter when you install it you also have to add quite a bit of trans fluid and lots of times people just forget to do that little task. Another common error before initial start-up is to add trans fluid till the dip stick say's full but once the engine starts and the trans pump is working it sucks all the fluid out of the pan to fill up the converter and nothing will happen when the trans is put in gear. Been there done that.
With the engine running check the trans fluid level and add accordingly.
Old 11-08-2006, 09:46 PM
the flexplate is bolted on, and i put in fluid before i started it...but i haven't checked it since it has ran....good idea....anyothers if that is not it???
Old 11-09-2006, 12:11 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I've been working w/ auto trannys for nearly 40 years and fluid level in them is still black magic. I can never be really sure what the level is in them since you have to measure that with it running and hot so fluid is thin and splashing all around inside. Add to that I usually chrome my dip sticks which makes the fluid line invisible and I am really in deep water!! Anyway, I agree with the others, make sure you dumped the 20 or whatever pints they recommend in the unit on initial fill then top it off when it is running and warm.
Old 11-09-2006, 09:10 AM
re: Im sure this is a stupid question, but...
Transmission shop here.
You don't need to put fluid in the convert first, what we do is to put 4 qts in trans, start the car letting it idle in park, add another 4 qts, this will fill the converter itself. Now you have 8 qts in it, with the rear end lifted, put the car in reverse, reverse is in the back of the transmission this will allow the fluid to go all the way to the back of the trans, leave it in reverse for a seconds, then go through the rest of your gears. Now start checking your dip stick remember to check both side of the stick reading the highest point. depending on pan size, and cooler, it could take 8-10 qts. If your level is good and you don't have any movement from your trans, then either you didn't put the converter all the way in the pump or your pump or convert is bad.
Old 11-09-2006, 10:21 PM
Wiki Edits: 21
One time I didn't engage the dogs on the converter into the pump properly. I cranked the engine over and the dogs were pressing against the rotor of the pump and chewed it totally up. HAd to completely rebuild. Not a good story but is easy to do and would cause the problem you are having.
Old 11-09-2006, 10:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
goes back to bolting on a pressure gauge to the tranny , port is on the side of the case ( passenger) near the vacuum modulator. 1/8 inch pipe thread plug in the port usually.
or open up a cooler line , then fire up the engine to see if the tranny pump is pushing fluid.
Old 11-10-2006, 09:41 AM
I'm sure this is a stupid question,but...
Remember,there are no stupid questions. Only stupid people that ask questions.
My wife tells me that. I wonder what she means by that.
I think I'll ask her.
Stupid timing question hlweyl Engine 5 02-11-2008 07:42 PM
Stupid question... but 5.0 freak Engine 5 08-31-2004 07:47 AM
very stupid question ? pjsplayhouse Body - Exterior 3 11-09-2003 04:21 PM
Stupid Question!!! !!! !!! Selwyn3III Engine 6 10-28-2003 05:43 PM
This may sound like a REAL STUPID question Nos General Rodding Tech 18 06-11-2003 07:04 AM
