Im terribly conflicted... Carbs - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-23-2012, 07:56 PM
vinniekq2's Avatar
I plugged in a few numbers to that calculator
Calculate Required Induction Airflow CFM
Use to determine how large a carb or throttle body to run
Engine Displacement (cubic inches only): cubic inches
Manifold type: Dual Plane Single Plane IR (no plenum)
Volumetric Efficiency @ red line: %
Red line RPM: RPM
Required CFM: 716 to 896 cfm (calculated)
so what carb do I use? rofl?650? 900? that was using a mild 355 at 93% VEjust over 6k redlin
  #17 (permalink)
Old 10-23-2012, 08:00 PM
Last journal entry: was hoping for better than this
Red line RPM: RPM
now do it at a more real 80% v/e
  #18 (permalink)
Old 10-23-2012, 08:37 PM
vinniekq2's Avatar
If your engine runs at 80% efficiency then fix it
  #19 (permalink)
Old 10-23-2012, 08:55 PM
Funniest thing I heard today......
  #20 (permalink)
Old 10-23-2012, 08:57 PM
not really, as most don't get anywhere near 90%
  #21 (permalink)
Old 10-23-2012, 09:02 PM
All I know is,
350,
Alum heads, 10.5:1
525/525
Air gap
Long tubes
It ran fantastic with a BG 650
I swaped to a BG 750
It went 2 tenths faster
Consistantly..
Yes it gave up some low speed response.
But it went 1.6 MPH faster almost every time.....
  #22 (permalink)
Old 10-23-2012, 09:07 PM
I wasn't arguing its merit as admittedly its over my head......it was funny tho....you gotta admit.....and if his combo is figured out and needs, and makes more power with a big Carb....then the bottom line is, on the whole....the bigger Carb will outperform the littler one!
  #23 (permalink)
Old 10-23-2012, 09:15 PM
358cids with 390 carbs, made so much power they added plates to slow the cars..
there is tons more to it than just stabing a 750 on a 350 and calling it good.
  #24 (permalink)
Old 10-23-2012, 09:22 PM
vinniekq2's Avatar
390 carbed roundy round cars used longer duration on the intake side.non restricted engines in the same cars made a lot more horse power. My slightly larger carb on my engine works well,even though I only use 3.5 gears and probably too big of cam in most peoples opinions
  #25 (permalink)
Old 10-24-2012, 08:30 AM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
Thanks for the responses, im definatly going with a 750 on my 406 cubic inch. it that doesnt make 87% V.E what other alternatives would there be?
  #26 (permalink)
Old 10-24-2012, 08:46 AM
How fast is fast enough?
a 750 carb on a mild 406 is typically just fine. If its a street engine consider running vacuum secondaries.
  #27 (permalink)
Old 10-25-2012, 01:29 AM
mr mighty mouse
Thats exactly what im thinking now that this virtual dyno i have does the V.E calculater. the carb im looking at is quick fuels slayer 750 model
  #28 (permalink)
Old 10-25-2012, 05:00 AM
thread started with asking about a 350 now it's a 406?
  #29 (permalink)
Old 10-26-2012, 03:30 AM
mr mighty mouse
Well if you look at the first post it was a friend, and i was confused about his tail of a 570 carb on a 350. and he said somethings pertaining to cfm size and you guys went on and forgot i still have a block sitting, still in current construction of a 406. Theres been many delays on this engine build, been waiting patiently and id like to have it built by this upcoming spring. LOL if it wanst for my stupidity, i wouldnt have to get this thing line honed and line bored. As you can see im still learning each and everyday and the thirst for knowledge is instilled based off the laws and phsysics of every piece of the engine and what it does. so you can say im a big newton fan. And a guy looking to have some fun by the end of the build.
Ive also noticed something very intresting, what Techinspector has pointed out and many other dyno guys on this site, is on the kinda of engine were talking about and big block chevy,(idk if this is true for other engines like ford, dodge ect.) that at 5252RPMs peak torque meets horsepower. intriuging as it is id like to save that topic for another thread involving V.E and other things that could cotribute to this rule of horsepower and torque 5252 rpms
  #30 (permalink)
Old 10-26-2012, 06:21 AM
thats because hp that we think of is nothing more than a math formula..
not what that engine can do..
I'm willing to bet a 160hp engine can't pull 1/3rd what 160 horses could..
if it could you'd snap the chain(most front drive cars) or gear teeth everytime it shifted gears at wot at hp peak..
Wiring gone bad (terribly bad) 65Mustang289HIPO Electrical 19 05-02-2006 05:18 PM
carbs PopaG Introduce Yourself 2 02-05-2006 07:01 PM
Something is terribly wrong !!! HELP!! 59chevyapache Transmission - Rearend 4 11-25-2004 06:34 PM
Holley Carbs VS. Edelbrock Carbs. KeithB123 Engine 3 01-12-2004 10:42 PM
Need help!! WHAT CARBS?? ss crazy Engine 7 09-23-2003 06:09 PM
