im thinking about getting a bigger cam (383) Please read! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2010, 07:18 PM
Hi guys, i have a 383 that has been built pretty well for power. Right now its putting out 365HP and 427TQ to the wheels. At first I ran the engine on nothing less than 93 octane. Then as my wallet got thinner, i started using 89 and performance stayed the same and the engine never pinged or dieseled. I took a risk and added 87 to the 89 just to see what would happen. I decided i would add 87 to the tank until it started pinging or dieseling (if ever) and would add 93 to the tank to even it out if it did. Well now the tank has pure 87 in it, and ive been running it with 87 for a month now. Engine performance is the same and it dosent ping or diesel. Timing is set at 30 total centrifugal all in at 1600 rpm and 20 degrees of vacuum advance. This setup has been great for me!
Anyway, even if i have a straight pipe on this engine, it just isnt very loud. Today an LT1 w/ trick flow heads and a bigger cam fired up, and even with pipes all the way back, it was loud! And it wasnt annoyingly loud, it sounded great! I want that sound and realize that I need a bigger cam, but I dont want to go too big on the cam so I dont lose all the mpg i gained by using a t56. Basically my cruising speed is 1600 to 1800 rpm doing 70-80 mph. I dont want the cam to have to much overlap and have all my fuel going through the exhaust because the cruising speed is lower than usual carbed v8's.
Right now i have a comp cam 510/520 lift w/ 230/236 duration 112 LSA. What would you guys recommend for a nice cam that has a nice THUMP to it, that would also give me some more power on the top end? The engine has a holley double pumper 750 on it and its in an 87 trans am (about 3250LBS) with a T56 6 speed manual and a 3.42 torsen rear end. What do you guys recommend?
Old 11-08-2010, 07:46 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
My gut feel on this is don't mess with a good thing seems like alot of work for something that is doing so well for you??,,, but its your deal so,,,
you already have a pretty big street cam, can a bigger cam live with your compression ratio? what is it at?
you could look for a similar cam but with a tighter LSA for a more agressive idle.
2 more of my cents
Old 11-09-2010, 01:32 AM
That makes sense, thanks.
Old 11-09-2010, 08:16 AM
more rpm would = detination
It's kind of tough to put an exact handle on your combo w/o knowing the static compression. The 383 tends to reduce detonation tendancies due to the dwell of the piston near tdc. The cam you describe doesn't start building cylinder preasure until the rpms come past 3000 up due to the overlap. Most likely why your combo is quiet is because that it's burning the fuel much better than you friends combo that's what makes all the noise anyway.
Old 11-09-2010, 09:01 AM
Banned
Really?
Back to the OP, with such a low cruise RPM you don't want a larger camshaft, you can try holding the same intake duration and extending the exhaust duration but that will lower mileage. Narrowing your LSA will also lower mileage and make it harder to drive at that low of an RPM. To be honest it sounds like you have a really good combo, if you want a better sound try larger exhaust pipes and some good mufflers. Magnaflows make a sound that I LOVE and they are one of the least restrictive mufflers.
What are you currently running for pipes and mufflers? What size of headers?
Old 11-09-2010, 01:25 PM
Originally Posted by ap72
Really?
Right now Im running a 3" exhaust, y pipe going into an edelbrock true flow muffler w/ dual 2 and half outlets, w/ 4" tips. It dosent sound bad, but you cant even hear it at idle inside the car!
Old 11-09-2010, 02:00 PM
Banned
IS it possible for you to get true dual exhaust (no Y-pipe)? That along with some flowmasters will get you a lot of noise. I still prefer magnaflow but flowmasters will give you more interior noise than you want!
What size of headers are you running?
It looks like your money would be be spent on getting a better exhaust if you want more sound.
Old 11-09-2010, 02:28 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
yes these cars can have true duals put on them, i run 3" true duals on my 87' camaro. but you will have to have it done at a shop, because it will be a custom exhaust. for mufflers i like Dynomax, for the money they are the best flowing mufflers, Magnaflow are really good but a little pricey too, i dont like flowmasters at all, they have proven that they dont flow nearly as well as some of the other companies out there (like the ones i just mentioned). i use dynomax bullets, 3" center in/out with a 4" outside diameter, my rear suspension is adjusted to about 1.5" higher too + i use a 28" tire. if your car still sits at the stock height then you will want to avoid all speed bumps, or you could even just use 2.5" duals and you should be fine, a 2.5 dual still flows enough to handle up to 500hp
get rid of the Y-pipe and make sure that you are running a decent 1 3/4" longtube headers
Old 11-09-2010, 07:11 PM
Ive been thinking about lifting the car a couple inches for a while, do you have any pics of lifted trans am/ camaros? Im planning on going for 18" vette wheels. If i can lift it, ill go for 3" duals since i already have most of the piping.
Old 11-10-2010, 07:47 AM
my87Z's Avatar
to lift it you will need to buy new struts and shocks with knew springs, i acutally used QA1 adustable coil overs in all four corners with new springs, i had to do a little bracket fabrication but it was well worth it
Old 11-10-2010, 11:22 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
want loud, here in the car ................. side pipes, music to the ears and will give that hotrod a road racer look.
CAM HELP! Comp Cams XR276HR In a sbc 383 Chevystr383 Engine 21 01-02-2011 08:15 PM
Cam for 383 build v8hed Engine 30 03-23-2010 06:38 PM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
Chevy 383 What cam to run???? Also Forged or hyper pistons?? 89SDime Engine 19 02-27-2006 11:59 PM
383 stroker block and cam ???????? mupton Engine 1 01-26-2006 09:50 PM
