im thinking about putting ether a small block or a big block into my 99 s10 pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2013, 06:09 PM
how would I go about putting a small or a big block into my 99 chevy s10 pickup (standard)
Old 07-18-2013, 08:50 PM
vinniekq2's Avatar
buy a kit,bolt it in.
The Following User Says Thank You to vinniekq2 For This Useful Post:
antsfresh91 (07-19-2013)
Old 07-19-2013, 08:58 AM
Banned
use this link
Chevrolet S-10 Forum - The Largest Chevy S-Series enthusiast site : s10forum.com
The Following User Says Thank You to killeratrod For This Useful Post:
Old 07-19-2013, 10:09 AM
1971BB427's Avatar
I'd go with a SBC. A BBC is a tough fit, and will require a lot more mods to work in a S10.
The Following User Says Thank You to 1971BB427 For This Useful Post:
Old 07-19-2013, 11:05 AM
now with a sbc would I have to bang the fire wall and do any other modifications. and im guessing that the stock 5 speed manual trans would not fit on the sbc ?
Old 07-19-2013, 02:30 PM
I have a 86 and a 96 s10 both with v8's and did not have to bang in any of the firewall like some people do. The 86 has a little more room on the sides compared to the second gen s10 94 and up. I cut the front of the radiator support to move the radiator forward in order to run a mechanical fan and the cross member for the transmission had to be customized for a turbo 350 tranny and also the drive shaft had to be cut and made to fit the turbo 350. As far as mounts goes the 86 has welded mounts and the 96 has the 2.5 v6 motor mounts with a aftermarket brackets to fit them on the side of the engine. I could not tell you who made them as I bought the truck with a 350 vortec installed so I don't know and the guy bought from was Mexican and he could not speak English well so could not ask much.
The Following User Says Thank You to eric32 For This Useful Post:
Old 07-19-2013, 04:16 PM
ok cool now I have an idea of what I have to do thanks so id have to buy custom motor mounts and a tranny in order for it to run anything else I should know besides the info everyone has gave me
Old 07-19-2013, 06:07 PM
Proud LOSER
Yep, unless its a maximum effort motor use Shorty headers, the hassle of long tubes just isn't worth it, make sure your cooling system is bulletproof, I ran a big Howe alum Rad and twin elec fans on a stout 383 and it worked OK. If lowering watch your pinion angle or you may end up chasing driveline vibrations. Spend the money on a diff, the little 7.5 isn't going to live long in front of anything real strong....especially if it hooks. Buy a small cap HEI and you should have plenty of firewall space.
Old 07-20-2013, 10:03 AM
ProStreetRob's Avatar
5.7L S10 LS SS
Nothing like a powerful V8 in a pick up truck
I'm on my 7th and 8th right now, got a 90 Pro Street Sierra with a 502, 871, Dual Quads, etc... (just a 800-1000 HP street truck)
And I got a little 87 Pro Street Ranger with a 418 cu in 351W that runs mid 10's all day long on the 1320.
As said pay attention to the cooling system and exhaust, mounting it in is the easy part. I had some cooling issue with my old 88 Pro Street Ranger with a 383 Stoker in it at the beginning. Had to cut my radiator support and recess the radiator a bit to get a big enough one in there along with the twin fans. On my Current Ranger custom long tube ceramic fender well headers were made with a matching ceramic side exhaust and it was very expensive. On that I also run a big Alum Rad with twin fans and then I have a HUGE transmission radiator and fan underneath to keep the transmission cool.
Old 07-21-2013, 12:16 PM
ok thanks for all the advise everyone if I run into any problems I will definitely ask thanks again
Chevy small block and big block bolt lengths zmaxmotorsports Hotrodding Basics 17 03-01-2013 06:55 PM
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 08:36 PM
Is a 348 or 409 a BIG BLOCK or SMALL BLOCK? STATUTORY GRAPE Engine 35 02-16-2005 10:29 AM
396 Big block v.s. 400 small block Adrenaline_Fiend Engine 13 04-12-2003 05:14 PM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 08:06 AM
