Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I'm thinking about using a torch to lower the rear of my car...Thoughts on this?
Old 11-20-2009, 03:12 PM
mechEcwru mechEcwru is offline
I would just buy new coils. If you are did set on using the existing ones then You can cut a portion of a coil off, heat the part right by you cut the coil off and bend that part flat to seat on your perch. Since you heated the spring(ruined its properties) you have to send them out and get them shot peened at the very least.
