Im told my starter overheats on >20 minute drives... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2010, 02:47 PM
TheyCallMeTiny's Avatar
Tri-shield Terror
and that this causes the truck to not start for a few hours till it cools down.
Its a built Chevy 350 with Edelbrock long tube headers. Im told I need a starter heat shield to keep this from happening. Thoughts? Suggestions? Do I just have a starter thats fixin to go out? It starts right up every time if it hasnt run in 10 hours. Its just that the trips to get groceries or to drive around that make me nervous. I drove it home the first night, 30 miles. When I got it home, it wouldnt start for four hours but then started right up. When I say it wont start, I turn the key and get zero cranking, just complete silence. When it starts up fine, there is no cranking either, just turn the key and its running.
If this is a legitimate problem, where can I find a heat shield, or where would I go to get one made?
On a side note, my floorboards get VERY hot, so I know its putting off hella heat.
Sorry to the mods. I really didnt post this twice. It kinda just happened.
Old 08-31-2010, 02:54 PM
dinger's Avatar
Chevrolet's are notorious for this. Use a heat shield. If this doesn't do the trick, I believe there is a tougher solenoid and/or use a mini starter to pick up a bit more clearance. Note on the mini starter, every fool and their uncle are making these now, mostly off shore, buy one where you can get an easy return if needed.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 08-31-2010, 03:43 PM
Tri-shield Terror
I bought a generic heat shield for $5 at autozone. I guess its back to the drawing board if it doesnt fit.
Old 08-31-2010, 05:25 PM
SSedan64's Avatar
If that doesn't work bypass the Chevy solenoid & install a Ford type solenoid on firewall or inner fender.
Old 09-01-2010, 06:16 AM
Installing the remote Ford solenoid is also useful for other things than solving heat problems.
- Mounted o the fenderwell, it gives a very convenient place to hook up a remote starter switch.
- You use can use the large battery cable terminal on the solenoid as a junction point for an add-on accessory or a fuse box.
- Its also a good place to connect your alternator charge wire, if the stock one runs down behind the engine to the starter terminal where its hard to reach.
Bruce
Old 09-01-2010, 07:05 AM
poncho62's Avatar
Wiki Edits: 5
A heat shield may help, but chances are your starter is weak....bad bearing or something.......
Old 09-03-2010, 01:29 AM
New Member
________________
[url=http://www.***********[/url] I [url=http://www.********[/url]
Last edited by dinger; 09-03-2010 at 09:23 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 09-03-2010, 03:24 AM
SSedan64's Avatar
Dinger the SPAMMER copied your post this time.
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 06:47 AM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
Starter keeps starting and battery exploded Huug Electrical 13 10-06-2005 05:48 PM
Starter questions zipfactor Engine 6 08-07-2005 07:10 AM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
