Impact Wrench
Hey guys I'm new here and new to air tools. I am planning on buying a air gun but would like to know if they can be adjusted for different torque settings. What brands would you recommend?
EDIT- I want to add that the settings are not exact- and the settings will also vary as the compressor tank air pressure varies. The Ingersoll Rand #231 and the Chicago Pneumatic #731-2 (in the MAC cover) are the same tool. They are decent tools. In the 3/8" drive guns, the little Husky isn't bad, but I find myself reaching for the Matco more often than not. The 1/2" Blue Point is at the top for a reason. That tool and I have been together for a long time, it has never needed anything except oiled. I like the dial on the back OK, but the CP/IR tools can be reversed one-handed; the reverser (slides back and forth to change direction) and speed control (turn to change speed) is the knob on the back of the tool. The p os on the bottom is also there for a reason. It represents the flood of Chinese (Taiwan) crap that has inundated the US for the last couple decades. It's a "use it till it breaks, then throw away" $20.00 tool. It adjusts speed w/a dial on the bottom of the handle, direction changes are made by sliding the button on the back of the tool in or out. Same deal w/the 3/8" tools shown, although other controls are fitted to different brands. Other air tools you will want to look into are a couple air ratchets, and a good butterfly wrench to start with. Tools not equipped w/an adjustment can be easily fitted w/an adjustable valve- they screw into the air inlet port. If you were to go w/CP you should be fine, IMHO. Last edited by cobalt327; 11-07-2009 at 03:01 AM. |
I have two IR impacts myself - 1/2" and a 3/8"
I find that I use the smaller impact more often the then larger unless I need the extra torque. 1/2" Ingersoll Rand 2135Ti - 1000ft lbs ![]() 3/8" Ingersoll Rand 2115Ti - 280ft lbs
air gun
ingersol thunder gun is my favorite by far,lot's of power when you want it and can be turned down quite low,it's a versitile gun with two hammers in a tuff housing that will give you years of dependable use,as a mechanic of 30 years this is still in my box .would'nt be with out one.
| Recent Garage - Tools posts with photos |
| impact wrench | zz71s | Garage - Tools | 22 | 05-19-2008 07:06 AM |
| Old Craftsman Impact Wrench | scotzz | Garage - Tools | 10 | 04-23-2008 08:17 PM |
| Electric Impact Wrench - Are They Ok? | leejoy | Garage - Tools | 9 | 11-16-2006 09:03 AM |
| Air CFM Requirement for Impact Wrench | leejoy | Garage - Tools | 8 | 11-12-2006 12:38 PM |
| electric Impact wrench | boss350 | Garage - Tools | 8 | 01-20-2006 07:32 PM |
