Impala convertible cylinder pivot bolts???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2013, 07:29 PM
CHEVY 64's Avatar
hello all i was out working on my 1966 impala convertible,im replacing the whole system motor,hoses and cylinders but having a problem taking the cylinders off? can anyone tell me what size are the cylinder pivot bolts??? theres 2 bolts per cylinder holding into place,i got the outer pivot bolt out but the inner bolt is so close to the body its hard to tell what size it is,i would hate to strip the bolt in that tight space so im on here to see if any 1 knows what side that pivot bolt is and are they the same size????
Old 07-11-2013, 07:53 PM
Banned
honestly bring your sockets & wrenches with you and check for best fit, do you have beer i will come help you. holding hand extra.
Old 07-11-2013, 08:26 PM
CHEVY 64's Avatar
UPDATE- i just did i had did what u said,had a tool that seemed like it fitted perfect but like i said the space inbetween the bolt and body is like 2 inches and i kind of stripped the bolt so i stopped
Old 07-11-2013, 09:00 PM
Banned
ok you kind of striped it so get a vise grip tight on it and take it out. then look here for a new one.
Convertible Top Pivot Bolt Set, 1968-72 for 1972 El Camino @ OPGI.com
this link will get you to the site to look for your needs.
Old 07-13-2013, 04:50 PM
CHEVY 64's Avatar
I cant even get my vice grips in that space
Old 07-23-2013, 05:05 PM
CHEVY 64's Avatar
Im still having trouble
Old 07-23-2013, 05:06 PM
Post some photos, this isn't making sense.
Old 07-23-2013, 05:16 PM
Banned
ok i have to ask is the top down. if it is put it up and then try it. X2 on some pictures.
Old 07-23-2013, 07:20 PM
CHEVY 64's Avatar
The top is up idk because i stripped it just a tad but i tryed every tool i got,i would of grinded the bolt off but dont have no room to do this, will get pictures up tomarrow,thanks
Old 07-23-2013, 08:27 PM
Banned
try this a small pair of needle nose vise grips, if you do not have them you know what to do. this really should not be as hard as you are making it. unless you are like 6' 5" and like 350 pounds!!
Also did you soak the nut and bolt with WD40 or /blaster or and thing to loosen to rust??????
Old 07-24-2013, 01:55 PM
CHEVY 64's Avatar
I can tell you now needle nose aint going to work,i soaked the bolt in wd40 ,im 5`10 220 so i doubut that a factor, its just the space is smal to work in, the outter bolt is ok like i said becaise you got plenty of room to work but the inner bolt is so close to the quarter panel and limited hand movement
Old 07-24-2013, 03:25 PM
You only have to hold the one in the rear right? It isn't like you have to turn it, you turn the other end. I'm sorry I am not getting this at all. I just last year installed the ones in my car and there wasn't a big deal and these GM convertible tops are almost exactly the same at that time.
Old 07-24-2013, 03:29 PM
I think it's even something like this without a nut on the back at all??
Old 07-24-2013, 03:37 PM
Banned
yes sir Martinsr just like the link i showed him in post #4. 2 weeks ago.
intro new guy with 68 impala convertible project68impala Introduce Yourself 7 05-14-2013 09:29 PM
1968 Impala convertible hannes_slanec Suspension - Brakes - Steering 4 03-16-2012 11:57 AM
64 impala convertible naparra Introduce Yourself 1 01-28-2009 02:25 PM
1966 Impala Convertible Russ Mc Body - Exterior 0 12-04-2006 07:35 AM
69 impala ss 427 convertible bdrake General Rodding Tech 2 02-08-2005 05:58 PM
