impala master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2009, 11:41 PM
what master cylinder do i use if i wanna have a dual master cylinder on a 63 impala if i wanna still run drum brakes? ive seen a black plastic mopar cylinder and was wondering if it or another will work
Old 01-11-2009, 02:00 AM
techinspector1's Avatar
Wiki Edits: 326
If I understand you, you have a single master now that feeds all four drum brakes. You want to install a master with two chambers, with the front chamber feeding the rear brakes and the rear chamber feeding the front brakes. You want to know what size bore to use in the master cylinder to get the same pedal feel, travel and displacement of fluid. Does that about sum it up?
If so, you will have to determine the bore of the master that's on the car now. Let's say that it's 1 1/4". I have no clue what it is, but we have to start somewhere. If you find the square inch area of that bore by multiplying .7854 X bore X bore, you find that it is 1.227 square inches. So, lets say that with that bore, when you press on the brake pedal, the piston in the master goes 1 1/4". Again, I don't have a clue what it is, I'm just trying to show you how to figure this out. If the bore is 1 1/4" and the stroke is 1 1/4", then the volume displaced on a brake stroke is 25.13 cc's. (.7854 X 1.25 X 1.25 X 1.25 X 16.387 = 25.13) Now, if you are going to split the master and have two separate circuits, then you will need to cut the displacement in half on each circuit to displace the same total amount of fluid. Let's say that you found a master with a 7/8" bore. With a 1 1/4" stroke, each circuit would displace 12.3 cc's, so two circuits would displace 24.6 cc's. (.7854 X .875 X .875 X 1.25 X 16.387 X 2 = 24.6) That's pretty close to the 25.13 cc's you were getting with the single master and probably would work ok.
Old 01-11-2009, 05:47 PM
You might check on 67+ GM Chevelles Novas etc. Many had 4 wheel drums and dual masters.
Old 01-12-2009, 08:31 AM
inlinetube.com makes complete conversion kits for some of the more popular makes. The kit comes complete with dual-chamber master cylinder, pre-formed supply lines and, distribution block separating front and rear circuits. The kit appears to be a "bolt-in". I am looking to upgrade my '64 Tempest and am planning on purchasing one of their kits.
79 Camaro master cylinder leaking Scottrn Suspension - Brakes - Steering 3 09-20-2007 06:33 AM
HELP ASAP - 77 T/A Master Cylinder and Prop. Valve Question Torx Suspension - Brakes - Steering 1 06-26-2006 01:52 AM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
69 Impala master cylinder godsMistake Suspension - Brakes - Steering 1 09-23-2005 08:32 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
