Impala rear suicide doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2003, 05:35 PM
Post Impala rear suicide doors
Hi. New member here from New Zealand.
Ive got my hands on my dream car - a 4 door pillarless 64 impala. I am wanting to suicide the rear doors. There isn't much here in the way of door kits or advise.
Can anyone help in the way of pictures or a website? Im trying to draw up plans but the main problem is getting a hinge to sit neatly in the curved section over the wheel.
Im also wanting to use the same original door handles and latches to give it Lincoln Continental Look. Is this possible.
Help
Joe
Old 05-18-2003, 06:34 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
They made a 4 door pillarlless '64 Impala? Thats a new one on me.
Stick around, hang tight, I'll try and get on tomorrow and type you out some help if Dr. Chop or any of the other fine gentlman don't do it before I get back.
HK
Old 05-18-2003, 07:50 PM
Post
HK, the 64 Impala 4door hardtop is used throughout the movie "Mississippe Burning" starring Gene Hackman and William Defoe. It is being used as an FBI car, as if the GSA would have spent the money on a 4door Hardtop. Sure. Yeah right.
Old 05-18-2003, 10:27 PM
Post
Its actually a rare find. Its got power steering, air conditioning and power windows, all standard. But needs much TLC. Ive been looking for this one for about 5 years.
I just need the side on Lincoln look to make it perfect.
Old 05-19-2003, 07:04 AM
Madd Syntst's Avatar
Returning American Maddman
Post
I'll run this by old Dr. Chop and see what he says. This is an ambicious project to say the least. It will be way cool when done. Look at those new trucks with the rear doors or the new economy car that has the suicide door. The quadtro or something like that
Old 05-19-2003, 09:11 AM
EBlack36's Avatar
Rebuilt Excitment
Post
The Saturn Coupe has rear doors that are of a suicide type as do several of the club cab trucks.
Old 01-13-2004, 03:10 PM
Any further developments on this? I am in New Zealand too and am looking at doing thie, but to dare I say it a Jap import show car.
Old 01-15-2004, 06:18 PM
try www.autoloc.com they are pretty good,, im gonna suicideside my rear doors on my accord,they actually have the whole hinge kit, they may be able to set you up in that direction, you may also need to fabricate some things. call there tech line, they should be able to help you.
Old 01-23-2004, 07:08 PM
flamedfordbronco's Avatar
Last journal entry: finished
Joe,
Does the rear door curve up over the rear wheelwell? I have a 4 door 1964 Fairlane, and I've been having the same problem. there is only like a 5 inch space that is straight on the back end of the door, and I have a feeling that any hinge there would bend. I got a set of plans off of ebay for around 10 dollars, they're a series of CAD drawings and measurements to make your own hinges, the only problem is that the hinges are supposed to be spread farther apart than our cars will allow.
I'll tell you what I've been thinking of trying. I don't know if it will work, but I might give it a try and see how it goes. I was going to use the plans I got, and build a single hinge for the door (pretty much a stock GM hinge connected to new fabricated bars), but instead of just welding the hinge to the inside of the door jam, I was going to run a 1/2" thick metal bar all the way back the inside of the quarter panel and weld it farther back on the car (give it the leverage so it doesn't bend the door jam metal). Then you can just make your hinge pieces and make the arm a little longer on the door, so that doesn't bend either. I guess you'll have to see the plans to know a little better what I'm talking about, check out ebay and search for "suicide door plans". A guy named Chris Hicks makes them, he's based in Canada. Since you're in New Zealand he might just let me scan and send you pictures of them so you can see what I'm talking about.
If anyone else knows how to really do this, or understands what I mean and think it will work, let me know because I think Joe's impala and my fairlane would look awesome with the suicide back doors. Sorry if that is all confusing, it's a little tough to explain without a picture. Let me know how it goes Joe, good luck.
~Frank~
Old 01-23-2004, 10:20 PM
New Member
www.suicidedoors.com the best suicide door kit at a great price. many of us in the mini truck world use them and they are really high quality. also a great place for 4links, air suspension, and other neat stuff
