Imperfections on a aluminum intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2007, 09:56 PM
junkyardjeff's Avatar
I put a used aluminum intake on a 302 in my 65 custom 500 and it ran like crap,changing carbs did nothing and it was running lean on 4 cylinders so the intake came back off,I noticed around a few ports there were gouges where someone had ground off a old gasket. How much imperfections are ok for it to seal and could sealer have been used to make up for the gouges. Jeff
Old 05-20-2007, 12:15 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You could try some JB weld as that has been used to repair aluminum manifolds..once you have applied the JB Weld then use a piece of metal block with some sandpaper to get the damaged areas straight again..then we hope it seals well for you..
Sam
LT1 Question DV8 Engine 10 01-08-2007 12:59 AM
Painting Aluminum Intake 123pugsy Engine 11 11-16-2006 06:57 PM
Lifting a motor by the intake junkyardjeff General Rodding Tech 51 09-20-2006 09:37 AM
62 corvette aluminum intake manifold custom Engine 1 10-22-2003 09:49 PM
327 GM stock aluminum intake. slider in wa Engine 2 10-25-2002 05:38 PM
