Importance of Adjustable Voltage on MIG welder - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2003, 11:37 AM
I searched (really did), but still have a question on selecting a MIG welder. How important is it to have an infinately adjustable heat setting? I'll mainly be doing body panels, but will also be doing a sub-frame using tube approximately 1/8 thick.
BTW, I found a Millermatic 135 (infinite adjustable heat) with cart, extras and no shipping for $540. Sounds good to me, what'ya think?
Thanks
Old 07-07-2003, 12:20 PM
I used a mig and arc welder and the only time i adjusted the voltage or amprage is going from welding 1/8-1/4 to 3/4- +. The mig did not handel the bigger stuff, did great on small stuff.
If you never used a mig before do some practice a bit to insure good penetration of weld ( voltage = heat )
I'll check with the weld shop at work to the settings for sheat metal if your not shur on that.
Old 07-07-2003, 02:56 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
i have a mig with full adjustability and haven't used anything other. but i'll bet if you go with the preset models and you need something in-between two settings, you'll be kicking your ***** that you didn't go for the other one. i'd go with the better model as you can tune in the welder to whatever you need.
JB
Old 07-07-2003, 06:46 PM
woodz428's Avatar
Troll Hunter
Arrow
I agree, the infinite adjustment is a definite plus.
Old 07-07-2003, 07:31 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I have a Hobart 175 handler with the preset heat selector. I have never had a problem. You just have to adjust the wire feed for the job. Infinate would be a plus, but it will work fine without it.
Chris
Old 07-07-2003, 09:53 PM
This is the best site for discussion of welding products and processes.
Even though it is hosted by Miller/Hobart, they are quite unbiased and really let people have open discussion about various other brands.
http://www.hobartwelders.com/mboard/index.php?s=
