Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 01-03-2004, 03:49 PM
71gtx 71gtx is offline
Important rear end mounting question
Alright guys, I made bushings for my rear end to set onto the leaf springs. I used solid pipe that i drilled a hole into and pinned it through the springs. There is one problem and I need to know if this will affect my driveshaft angle into the rear end.
The holes i drilled were slightly off centered. I mounted the drivers side spring to rear end first and then the passenger side. However, the passenger's side would not but up because of the off centered hole on the drivers side which moved the mounting point over a slight amount. So I pushed in the spring and got it to bolt up.
Both sides bolted up, but since i had to move the right spring in (because the rear end became off centered slightly), will this cause a problem for the driveshaft to rear end yoke?
By the way, my right tire used to stick out more than my left, perhaps this mistake could benefit the centerline?
Old 01-04-2004, 10:18 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Overqualified Underacheiver.
 M&M CUSTOM's barnstar
re: Important rear end mounting question
I wouldn't worry too much about the centering of the driveshaft.
If you were to have installed a ford 9 inch rear they are not at all centered for the pinions' input.
The only thing about your set-up is the spring bushings are tweaked a little, you may notice it acting a little smoother than before.
But it may also wear them a little quicker too, unless you switched to polyurethane bushings.
Old 01-04-2004, 06:05 PM
ok thanks for your help. i got her all bolted up and new shocks installed. just have to figure out an odd brake problem now. whats new?
what happened was when I went to install the brake hose to the rear end, it naturrally wound itself up in a snake fashion, so i couldn't reattatch the mount. however, where the brake hose meets the brake line, the brake line won't unscrew because it wants to strip. so is there any way for me to unwind the brake hose?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
