Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - imported square weave wool carpet
Old 03-27-2013, 07:26 PM
John long John long is online now
Originally Posted by DanTwoLakes View Post
John is right about his car, but if the trans tunnel in your truck is two inches high and is the same height front to back, or at least until the tunnel is under the seat, you can do it with one piece of carpet.
I don't know for sure, but I would say that with the binding on the edges of the carpet next to the tunnel, the floor areas are just butted to the tunnel. It may be sewn together, but it wouldn't need to be.
Dan is correct. Mine is separate pieces. I glued it lightly so it would not crawl. I also used a closed cell foam as insulation.
