Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - imported square weave wool carpet
Old 03-28-2013, 07:13 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Dan is correct. Mine is separate pieces. I glued it lightly so it would not crawl. I also used a closed cell foam as insulation.
That's exactly how I do carpet in those situations, but I use a different insulation. I use a product from Thermozite that has no foil on it. It is about 5/16" thick and 36" wide and is very pliable. Wool carpet is great. It wears like iron and is naturally resistant to a lot of things. I just ordered a pre-formed carpet set for a '47 Olds from one of my suppliers, and it was only $585. It's not square weave, but it is all wool. I thought that was very reasonable. BTW John, was that V-8 medallion original to the car's dash or did you add it?
