Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Impossible to find misfire
Old 09-23-2012, 11:50 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Do a cylinder balance test using a manifold vacuum gauge to find the weak/missing cylinder.
Dis able the spark one cyl at a time notting the vac drop.
Remove the valve covers and watch the valves move. Bad cam bad lifter
Try a different distributor.
Install a ground strap from engine to body firewall. (this is a must with a HEI dis.)
