Impossible to find misfire - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-24-2012, 07:23 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
I am using vacuum advance. It is hooked to the timed port.
  #17 (permalink)
Old 09-24-2012, 07:51 PM
RWENUTS's Avatar
If it idles pretty high cause of the cam then try plugging the vacuum advance. Even if it's on ported you might be getting a little vacuum to the dizzy pot.
  #18 (permalink)
Old 09-24-2012, 10:14 PM
Timing light shows 20 with the advance connected or not. Should be good there.
  #19 (permalink)
Old 10-13-2012, 04:57 PM
I thought I would post an update about this problem. I took all of my plugs to a mechanic and he told me there was something wrong with the distributor. Either the coil, or the module, or something not right with the pickup, even though it was bought new. He said he had seen several of the Mallory distributors bad out of the box.
The distributor was only around $125 new, so trying a new coil, then maybe a module, and then maybe even a pickup would add up quick.
Anyway, I was so tired of it all, I just jumped in with both feet and bought an MSD distributor, 6AL, and coil and that fixed whatever problem it was. I don't usually like throwing parts at a problem, but I figured this should fix the problem as well as being a lot better ignition system for future upgrades. It fired up and runs great. Better cold starting and runs smoother too.
Impossible head bolt! HELP! JMSTOY Engine 14 02-02-2012 09:27 PM
what looked impossible for me to accomplish! chop52 Introduce Yourself 4 12-16-2006 10:05 PM
Is this Impossible Stardrey Engine 1 04-25-2005 08:57 PM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 01:59 PM
Mission Impossible NAIRB Body - Exterior 5 02-02-2003 11:56 PM
