Best thing you could do to increase mileage is build the engine close to stock, but change the trans to a 700R4. The overdrive in the tranny will do more to boost your mileage than anything you can do to that engine.
X2 on 1971BB427's 700R4. The deep low in these boxes gets the truck launched without having to mash the pedal through the floor this will be a big help with your tall tires and high rear end ratio against 2 tons of truck. The Overdrive will cut highway revs way down allowing a fast cruise with hardly any throttle. The lockup converter alone is good for about a 10% improvement if you're on the highway a lot. In the engine room the ubiquitous Vortec heads will pull up the compression and greatly improve the burn so you're getting the energy out of the gasoline you paid for. the cam you have is essentially the 300 horse, 327 cam. that was with 10.5 compression back when. Obviously you can't run that on an iron head today but you can run this more like 9 to 9.2. Given your big tires and high gear ratio the Swirl Port head from the TBI 350 would be a good choice, this tends to bump up the bottom end quite well and will fit conventional intakes where the Vortec takes a unique and somewhat pricey intake. For a carb either the Edlebrock/Carter or the Q-Jet, the smaller primaries will help your low RPM cruise while keeping some big secondaries in reserve for when maximum flow is needed. Unfortunately the pistons in the Goodwrench aren't the best configuration for chamber efficiency those circular dish pistons don't promote chamber turbulence. A change to D dish or flat tops would make an improvement but gets pricey since you have to get all the way into the engine. Actually on a cost to benefit ratio these changes will take a long time to break-even on fuel savings. Bogie |
can't do much more than what you already have.
however...... Skinny tires would help. stock 4bbl intake and qjet would also work well. headers are good idea. make sure the carb is tuned well. Put in a 02 sensor so you can make adjustments ignition timing is very important for good mpg. Use 15 initial, 37 total in soon as possible, plus 10 from the vacuum advance. Use the stock thermal fan. a tight convert will help too. use a regular oil pump (not high volume) you would be better off installing a late model 5.3, as it would be cheaper than to rebuild an old 350, makes more power, and gets better mpg. |
Edit: whew that a lot of work and money to put that in the simple truck. Not worth my time right now. I have to many other projects. Last edited by Catfish11; 02-13-2012 at 06:56 PM. |
You can get a complete 5.3 (fan to flexplate) with efi and all accessories fairly cheap. Prices will vary between 500 and 1000 depending on mileage.
Would need to fab in mounts, there are ways to uses your current trans, and some efi reprogramming to do also. Do some research when the time comes to rebuild the old 350. If you have some skills and some time, you could so the swap very cheaply. my 454/th400 gets 8 mpg around town and around 12 on the highway. When gas goes to 4 or $5/gallon. A 5.3 with od trans will paid for itself in short order! Only problem is I will need to change my name from 454c10 to 5.3c10 or maybe 6.0c10. |
| Needs best heads for fuel mileage on 355 | adantessr | Engine | 30 | 03-16-2011 08:30 PM |
| wiki: Improving fuel economy article coming along well | Jon | Engine | 0 | 06-12-2008 02:45 PM |
| brand new wiki entry: Improving fuel economy | Jon | Engine | 2 | 04-30-2008 07:34 PM |
| Pontiac 455 - improving gas mileage? | aguila1 | Hotrodding Basics | 16 | 03-19-2007 09:13 AM |
| Improving mileage on 350 throttle body | macx | Engine | 9 | 01-31-2005 09:41 PM |
