Improving your HF bead roller - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-03-2014, 06:29 AM
deadbodyman's Avatar
Wiki Edits: 11
Now you have quit preaching and started meddling................
I have had those vice grips on my tension bolt for 20 years.
John
No John, I meant the toggle clamp works like vise grips do..LOL ...
all my vise grips are holding my car together...its always nice when I pull it in to do some work and find a few pairs that I forgot about ...I,ve got one pair that's been clamped on the window reg for about five years but 20 ....that's a long time...
BTW.....if you guys need a great source for cheap hardware like sprockets,gears ,shafts etc....try surplus center or McMaster -Carr They got all kinds of cool stuff at a great price, everything you need to build a bead roller. As soon as I get a little time I'll be building a motorized bead roller with a 3' throat.....
  #17 (permalink)
Old 04-03-2014, 06:50 AM
I actually bought my sprocket from surplus center. You are right the do have some cool stuff. My sprocket was machined wrong though.
John
  #18 (permalink)
Old 04-07-2014, 08:13 PM
put up or shut up
this is about far as I go on it but I will probably spray some 2k undercoating on it. Rubberseal makes one that looks like a semigloss. I think that would look cool.
Model T steering wheel with the original crank butchered to fit the shaft and used as a shaft collar that's welded to the steering wheel. The handle of the original crank is also welded to the tensioner bolt. Used 1 square stock to strengthen it and also welded in pieces of it as gussets for strength. It works great now!
The Following User Says Thank You to tech69 For This Useful Post:
John long (04-07-2014)
  #19 (permalink)
Old 04-08-2014, 06:44 AM
Wiki Edits: 11
Are those the embossing rollers you made ? I've never done any of that but I'd like to....how did you make them and do they work well?
That's a pretty clever use of the original hand crank ,mine is still sitting in my pile of useful steel...(most people call it a junk pile)
  #20 (permalink)
Old 04-08-2014, 08:45 AM
Wiki Edits: 27
quick release
I used 49 cent brackets form the steel supplier I use from the wrought iron parts aisle . the toggle clamps are about $ 10 from Reids or other suppliers.
a pict of mine on post 47.
Converting bead roller to power
  #21 (permalink)
Old 04-08-2014, 08:52 AM
Wiki Edits: 27
HF dies.
My son bought a short throat bead roller and ,put on a high speed electric motor to remove insulation from scrap copper wire. It has a guide and the wire runs between 2 flat rollers. I got all the dies he did not use. I tried recontouring some on the lathe and was suprised how hard they were. even after heating them to anneal they were still harder than I expected from harbor freight
  #22 (permalink)
Old 04-08-2014, 09:37 AM
put up or shut up
no, the ones I made weren't true. It could have been because they were 7/8" washers and not 22m. I grinded them down on my "lathe" (angle grinder) to shape them. The problem was when I was welding the washer to the collar, right on the bead roller rod itself, I had to center it as best as I could before tightening, and that was the problem. Get 22m washers if you try it. The ones I made actually work better than these Hoosier ones performance wise but since they are not true they apply a lot of pressure on the tensioner bolt and I didn't like that so I got these. Had I known, I would have asked them to round the edges on these a tad. I might place another order with them soon and see if I can send them in and have them round the edges. Would really make them the cat's meow.
  #23 (permalink)
Old 04-08-2014, 05:37 PM
Wiki Edits: 11
Tim are you left handed? I noticed your shafts are mounted on the opposite side as mine...
  #24 (permalink)
Old 04-08-2014, 10:10 PM
Wiki Edits: 27
lefty
My son who has put the most miles on it is left handed. It was really an opps. I had it all apart when installing the drive motor. I use 1 in solid stock for tool mounts and have trailer hitch type receivers around the perimiter of the 4 ft southworth lift table, some square and others at a 45* angle . also some on tool stands and on the flat bed truck and trailer. It's handy for a portable vise, rebar bender, pipe vise , etc.
  #25 (permalink)
Old 04-09-2014, 07:30 AM
Wiki Edits: 11
That does sound like a good idea.I bolted my vise down to my welding table and its always in the way when I work with the bigger stuff.
  #26 (permalink)
Old 04-10-2014, 05:09 PM
Wiki Edits: 11
I had a few minutes of play time today so I welded a bracket to mount my 5.00 HF laser. sometimes you need to stop a bead at a precise spot, the laser makes it EZ to see where the centers of the shafts are for exact starts and stops.
The Following User Says Thank You to deadbodyman For This Useful Post:
John long (04-10-2014)
  #27 (permalink)
Old 04-10-2014, 05:30 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I don't mean to de-rail this Thread, but I since it came up (Dies) I thought I'd ask:
Where is everyone getting their Dies?
I purchased my tipping Dies (and others) here:
Bead Roller Dies
And, after looking around, I found these guys (but I don't know how good they are, and the pictures look a little suspect):
TraDa, llc - "The best way to roll"
Anyway, maybe you know a better source (or, make them yourself)-
  #28 (permalink)
Old 04-10-2014, 05:33 PM
Wiki Edits: 11
Do they fit the HF bead roller? I'm using the ones that came with mine...but my shop neighbor is a machine shop with a CNC lathe, hes making me a set of stackable dies but I figure if I bug him enough he'll teach me how to use it and I'll make my own...
  #29 (permalink)
Old 04-10-2014, 05:37 PM
Wiki Edits: 27
laser
Lazze has one of those lasers on his english wheel video , a grid on the sheet metal then it;s easier to get equal angles each pass with pushing and pulling the sheetmetal.
  #30 (permalink)
Old 04-10-2014, 05:38 PM
35WINDOW's Avatar
Yes, they are made specifically for the HF Bead Roller! Hoosier Pattern (it used to be called) has been making them for about 8+ Years or so (I believe they may have been the first to do so)-
Converting bead roller to power John long Garage - Tools 69 02-02-2015 07:27 AM
powered bead roller??? need help in choosing. tech69 Garage - Tools 0 03-06-2013 01:37 PM
bead roller size freeskier Garage - Tools 0 02-22-2011 08:15 PM
Using a bead roller...backwards... AngliaBob Body - Exterior 2 02-20-2005 09:19 PM
Using a bead roller backwards??? AngliaBob Body - Exterior 0 02-18-2005 07:21 PM
