Think i am going to need one for my 9" rearend pinion main nut.One person says 6-7 inch pounds .The other says 125lb torque setting -is right.So i am lost a bit here.Anyone have a link to a picture of a INCH LBS T-wrench? any help Iam grateful. bob s
The 6-7 inch pounds reference is for the "crush sleeve" bearing preload (after the nut is tightened). 125 ft pound nut torque is the reference to achieve the 6-7 pounds preload. Sounds confusing. Research further for a better explanation. Hope this helps. Pic below is an "inch #" torque wrench.
the suggestion of the inch lb torque wrech was for the checking of differential pinion bearing preload.. in the transmission forum, clik here for thread
You need a dial indicator type inch lb wrench or a T bar style wrench. A clik style wrench will not function correctly in checking the pinion gear spin pre-load torque needed
Below is a link to Jegs tech, showing differential adjustments to give you an idea, there are many more tutorials online;
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
