Increasing P/V Clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2013, 08:27 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I need to increase the P/V clearance on our motor for the Sprint car. I'm really looking for ways to do this without changing pistons since they are new. The pistons are JE (SRP) domes and I have talked with them about cutting the valve reliefs deeper and they said that .030 is about the maximum I can go safely which still is not enough. The problem is the exhaust valve clearance, the intake is fine. We dropped a valve during a race and during disaasembly, I notice that every exhaust valve had been "kissing" the top of the pistons. The heads are being repaired now with all new exhaust valves. I also will be buying a new set of rods since it appears there are some that are slightly bent and making the piston crooked in the bore. This could also affect the P/V clearance but I still would like more clearance. My question is what would be the best way to increase the clearance? I am not wanting to change rocker ratios, currently I have 1.5 exhaust and 1.6 intake. I'm running this cam but would consider changing it if that would help.
Isky Racing 201ASCS11 ASCS 360 Solid Roller Cam, Sprint, 4500-8300 RPM
Thanks
Old 06-15-2013, 11:01 AM
What is your clearence currently? You need to know if you have a clearence problem or a valve lofting problem.
Old 06-15-2013, 11:18 AM
Is there a chance you could use a thicker head gasket?
Old 06-15-2013, 03:13 PM
Banned
Lots of ways to do it, how much are you looking for?
Old 06-15-2013, 03:25 PM
S10 Racer's Avatar
Well, I need to check how much I have once I get the heads back but because the exhaust valves were hitting the pistons at high RPM, I am guessing around .070 or so because the indentations in the pistons range from .000 to about .020
Old 06-15-2013, 03:47 PM
Banned
.070" is a lot more than I was guessing. Maybe the easiest way would be reducing your rocker ratio on the exhaust or changing the lobe on the cam.
Old 06-15-2013, 06:45 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
You can also advance/retard the cam change the valve events in relation to the piston.
Old 06-15-2013, 10:06 PM
vinniekq2's Avatar
retard the cam,machine the 30 thou,sink the valves
Old 06-16-2013, 06:22 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
You know what S10racer.I am after reading your posts kind of disappointed in you that you didn't measure this out during the build.Really I thought you have a handle on things.
Something doesn't feel right to me on this thing.Call it a gut feeling or what.Don't know.Are you sure about the measurements you taking??. Are you sure that your not having valve float with the wrong springs or one that are either weak or installed at the wrong height or springs that are not rated for either the cam you have or RPM range.
I'm saying I guess,go back and triple check you measurements before you start changing anything.
Old 06-16-2013, 06:33 AM
Retarding the cam will make P/V clearance on the exhaust worse. Advancing will help but will hurt clearance on the intake.
Most exhaust valves stick out of the head. On my circle track engines I will drop the exhaust valve .015 to .030 more then the intake which will help in over lap.
The Following User Says Thank You to CNC BLOCKS NE For This Useful Post:
vinniekq2 (06-16-2013)
Old 06-16-2013, 07:17 AM
vinniekq2's Avatar
Thanks cnc,had a brain fart.I had intake issues on a 454 and put the cam in 2 late
Old 06-16-2013, 11:15 AM
S10 Racer's Avatar
I did measure it and if memeory serves me correct the exhaust was at .060 but after I tore it down, I noticed that there are some pistons sitting in the bore crooked by .040 (front to back) so that will affect my clearance as well. It looks like there is more than one thing going on that is causing this issue. I am in the process now of looking to see if there are some rods that are bent, they are Lunati I-Beams. It's very possible that there is some valve float because of the springs. I am having the machine shop check that out as well. It just does'nt make sense to me if it was valve float it would only affect the exhausts. I know the exhaust is more critical than the intakes because the piston is "chasing" the exhaust valve during the exhaust stroke. The valve assembly should be stable, using T&D shaft rockers and 3/8" Comp Chrome Moly push rods.
Old 06-17-2013, 04:18 AM
1Gary's Avatar
I'll go with bent valves,but bent rods too is alittle over the top for valves just kissing the pistons tops.Are you very sure this cam is installed right????. Ya know long durations on the exhaust side cam profile...
Increasing HP 66 ChevyHotRodder Hotrodding Basics 3 03-18-2011 01:57 PM
Increasing of engine bay Nightrider Body - Exterior 26 02-27-2007 06:07 PM
Increasing Performance nrh General Rodding Tech 8 08-29-2003 02:33 PM
Increasing Compression meschnebly Engine 14 08-13-2003 05:56 AM
any ideas on increasing hood clearance? swoodard23 Engine 9 01-14-2003 06:03 PM
