increasing recovering time on compressor - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-28-2009, 12:53 PM
rodin better than $** any day
yes it is in a garage that is not heated, when working in there i do turn on my turbo heater. other than that it is not heated at all.
  #17 (permalink)
Old 12-28-2009, 01:18 PM
Just a note about keeping any compressor in an unheated area during freezing weather, watch for that unloader valve line freezing up! Any time you start any compressor, new or otherwise, that has been sitting idle in freezing weather watch it until it builds up to shut-off pressure and make sure you get that momentary hiss when the pump stops. It's not at all uncommon for a drop of water to be somewhere in the line or valve preventing it's proper operation if frozen. Usually the compressor will start OK the first time if the pressure is a little low but after the first cycle the motor may have to try to start the pump turning under a load if that unloader is plugged off by ice. A tripped breaker is the usual result when this happens but a damaged motor is a real possibility too!
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Air Compressor Question Ezudin Body - Exterior 4 07-13-2008 09:05 PM
1st time engine rebuild problems. J77 Engine 8 06-30-2008 04:43 PM
Compressor question SlowB16 Body - Exterior 1 05-07-2008 11:05 AM
What type of compressor? Skipr Body - Exterior 1 05-29-2006 08:00 PM
