Indentify this GM manual trans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2013, 02:53 PM
hi there iv got a manual gear box, GM 6261888 is stamped on the side. is this box any good? it needs new linkages, are they available?
Old 03-02-2013, 08:12 PM
RWENUTS's Avatar
Take a pic of it.
Old 03-02-2013, 08:14 PM
gear box
steering gear box or transmission gear box? photos would help greatly
Old 03-03-2013, 11:35 AM
Wiki Edits: 85
Apparently you did not use your friend (Google).
Old 03-04-2013, 12:14 AM
Here are a couple of photos of my GM 4 speed manual engine transmission and linkage set up. It has been modified and does not work very well, first gear is very hard to find. Would like to know what sort of gear box this is and will it be suitable for a 451 Ford v8? Am I able to get a gear shift linkage set up for this gear box?
Name:	IMG_0033 (480x640).jpg
ID:	72003   Click image for larger version
Name:	IMG_0031 (640x480).jpg
Old 03-04-2013, 07:19 AM
cast iron Saginaw. I wouldn't put it behind a 350cid...anything in a performance application; let alone getting a conversion pilot bushing, and a linkage of some type (Hurst Mystery shifter perhaps) They're worth about 300 dollars if it has the right ratio to the dirt track guys, or someone is a serious resto nut.
Old 03-10-2013, 02:48 PM
junior stocker's Avatar
Like autogear said, Saginaw; and it's the Vega-Monza unit to boot as it has the mounting on the extension housing for an anti-vibration weight to be attached. It would also have either a 3.11:1 or 3.50:1 first gear. Hurst still makes shifters to fit. Butch/junior stocker. The linkage you show would have bolted to the crossmember, not directly to the trans; that's why they were'nt very good. With torque, the rods would get stressed and twisted up somewhat, making powershifts difficult. And what's with the adapter? Ford bellhousing?
gm column...indentify frank leigh General Rodding Tech 2 10-14-2011 08:00 AM
Can anybody indentify this Edelbrock flathead manifold? 27stutz Engine 7 05-06-2011 01:02 PM
Help me indentify this starter (sbc) 85Sierra Engine 6 04-26-2006 01:19 PM
Help me with a manual trans... SecGenLvr Hotrodding Basics 2 02-16-2006 05:03 AM
need help with manual trans ID Scuzzy Transmission - Rearend 3 10-02-2003 12:27 AM
