independant rear suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2007, 11:51 AM
I have a couple Jag independent rear suspensions, measuring aprox. 61.5 inches circa 1970. I'm not sure from what series they are from XKE OR WHAT? any feed back greatly appreaciated. Spero
Old 02-20-2007, 01:22 PM
I believe that all E-type Jags had knockoff wire wheels and the J-series sedans had bolt-on wire wheels. If the hubs are spined for knockoffs, E-type, if bolt flanged, J-series.
Old 02-20-2007, 11:05 PM
Pudycat
XJ6 series II or III
68 was the series I, early and mid 70s would be the Series II or III. Not much changed. They did my a positrac. The center differential can be changed out easy. I have a 1965 Jag with IRS and replaced it with a Series III, posi with 270 gears (did not want the Chev 350 winding at highway speeds).
The only shocks are the Koni coil over (4 of these at over $100 each add up). I saw another post here where someone was trying to fit air shocks.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Jag XJ6 rear suspension with air rides ???? jimcar-9 Suspension - Brakes - Steering 18 06-17-2009 02:48 PM
Rear air suspension design ccrodder Suspension - Brakes - Steering 12 07-25-2006 12:14 AM
Independent rear suspension on an f-100, can it be done/ trowley Suspension - Brakes - Steering 2 09-15-2005 09:57 PM
rear suspension on street rod 455 Ken Suspension - Brakes - Steering 7 03-11-2002 06:02 PM
