Independant Or Solid Axle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2008, 06:52 AM
I have a 1989 Chevy 1 Ton. Right now it has the factory independant suspension. I'm wanting to lift it. I'm wanting to build a mud bogger. I want to run 44's. I've seen lift kits from whiplash for the independant but im not sure how well it will hold up to the abuse? So I'm thinking of going with a Dana 60, or find an old 1 Ton chevy axle to convert it with. I'm running the 350 TBI with a turbo 400 3 speed, with 4:10 gears. I'm looking for some Ideas, or input. Thanks.
Old 12-19-2008, 09:28 AM
prostreet6t9's Avatar
Differential/Driveline
You would be better off in the long run to put the Dana 60 straight axle,There is some kit's out for that. When you put a big lift it put's your CV axles at a pretty good angle and then you add the 44's and they will be your weak spot. With a small block and the 44's you would be happier with some LOW gears so you have enough wheel spin to keep those tire's cleaned out.
Old 12-19-2008, 09:32 AM
http://www.offroaddirect.com/products.htm
http://www.offroadunlimited.com/orus...p?idCategory=3
Old 12-24-2008, 03:28 PM
Straight axle is the only way to go. If you get into it, any money you put into the IFS will eventually get cut off.
Axle? 31chevy Suspension - Brakes - Steering 2 09-02-2007 12:08 AM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 07:50 PM
Solid axle in 240SX??? vroomchu Transmission - Rearend 1 04-24-2007 04:28 PM
transverse spring & straight axle 26trackt Suspension - Brakes - Steering 3 01-18-2003 11:45 PM
34 ford truck front axle ideas and questions lilred34truck Suspension - Brakes - Steering 1 10-30-2002 05:20 PM
