Independent - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2002, 10:26 PM
Great '48 Bow Tie
Guest
Post Independent
I want to put an independent rear suspension under my '48 Fleetline. Will a Thunderbird/Cougar fit my chasis if not, what will make the transition possible? I would like a ford 9" with disk if I can hang it in there. Also would like to know if someone can give me a ballpark figure to have the front suspension removed from the Fleetline and install a mustang ll. I am not physically able to unbolt and remove the unit and install the Stang, but I don't want to get ripped off by some slick wrench turner. I expect to pay $2000.+ - for the IFS.
Al
Old 06-02-2002, 04:07 PM
FASTFORD's Avatar
Post
get an after market unit if possible. they will have all the little bugs worked out and designed for your size & weight car. it will save u in the long run. good luck.
