independent air shocks... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2005, 05:40 PM
is it a good ideal to run seperate air lines to each air shock? it's for a 6cyl chevyII 1966
Old 10-15-2005, 08:26 PM
Most definitely. If you connect them to a common air supply, it will cause excessive body roll in corners. The outside shock will be compressed, and it will push air into the inside shock, which is already rising due to cornering forces. It makes it act a little squirrelly, if you know what I mean. And if one side springs a leak, they both go down.
I had to get the Sears guy to dig around in his junk box to find me an extra inlet valve, but you might be able to get the same parts at a hydraulic supply place.
Old 10-15-2005, 08:58 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Auto Zone used to have the separate fill valves available in their paper catalogs. If you can find somebody that isn't totally clueless that works there.
You can also use two dual outlet fittings, and use a plug in one fitting on each.
Old 10-24-2005, 04:41 AM
Not really an issue on a 6cyl Nova, but with independant air shocks you can tune the car at thetrack or with fat drivers.
Air Compressor Types- What do you have? ChevelleSS_LS6 Garage - Tools 135 11-01-2014 08:49 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
Air shocks?? Andrew7dg Suspension - Brakes - Steering 6 11-17-2002 09:09 AM
