independent rear suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2003, 10:26 PM
Question independent rear suspension
I have a 49 chevy truck and i would like to put an independent rear suspension on it. I was thinking about a jaguar rear end or a c4 corvette rear. Does anyone know what is involved in installing a jag rear into my truckor how difficult it is? I would really appreciate any advise. Thank you!
Old 05-24-2003, 06:31 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Post
A Jag axle isn't to hard to install. Most people take it out of the "cage" that Jag uses and make a crossmember that passes over the differential. That's easy enough to do if you can weld. From there you just need a pair of arms -- I used a pair of four link arms with adjustable ends from Pete-n-Jakes. To see what I mean, go to <a href="http://groups.msn.com/AMCsForever/classicgtwproject.msnw" target="_blank">http://groups.msn.com/AMCsForever/classicgtwproject.msnw</a> and see what I did to put one in my Rambler wagon. The width is misleading if you go by the factory published tread width (from center of tire to center of tire) of 58.6". The hub to hub width is closer to 62" -- the Jag uses a deep set wheel on the rear. Rather than narrow my axle I bought 7" wheels with a 5.5" backset. These are hard to find with the old rear drive Chevy bolt pattern that Jag uses 95 x 4.75" circle)!! The hubs can be redrilled for a 4.5" circle, but the hubs have to be fully disassembled and I'd already rebuilt mine before i discovered they don't make front wheel drive type wheels in the 5 x 4.75" bolt pattern. 5 x 4.5" is still used though. The Jag isn't hard to narrow -- anyone with something to hold everything perfectly straight (especially the driveshafts) and a welder can do it. Go to <a href="http://www.jagoutlet.com" target="_blank">www.jagoutlet.com</a> for rebuild parts. I had to change gears -- most came with a 2.88 gear set in the mid to late 80s. You can use Dana 44 gears, but a special installation kit is required, which brings the price up to a point that you may as well buy Jag gears. 3.31 and 3.54 are common older Jag gear sets. For anything else you have to go with the Dana 44 gears and kit. Someone mentioned cheap overdrive and I remarked that a high gear rear end with an old three speed tranny between original trans and rear would be an effective and cheap means of attaining "overdrive". The three speed trans just uses 2nd and 3rd gears, with 3rd being 1:1. Same effect as using a two speed rear axle. Keep it in 2nd gear until cruising, then shift into 3rd to get the 2.88 rear gear.
Old 05-24-2003, 07:17 PM
Post
Funny, I seem to remember in the 70s and 80s when the Jag rear was the rear of choice the wonderful thing about them was that they used common GM gear sets and GM u-joints. Even the bearings for the hubs were readily available. It's a really good looking rearend even if left in the stock "cage". I figured when they seemed to fade away that the available supply of Jag rears had been depleted....after all, they ain't making anymore E-types, are they?
The wheel pattern on the sedan rears was the same as GM Chevy 5 on 4 3/4 inch circle. The E-types had splined knock off hubs for wire wheels. I believe the sedan bolt-type hubs interchanged to the E-type rears.
I might suggest you look under an XJ-6 sedan from the 70s/80s; it's probably the same basic setup.
Old 05-26-2003, 06:49 AM
farna's Avatar
Wiki Edits: 14
Post
They faded away because of cost and IRS really isn't necessary. The Jag uses a Dana 44 gear set, NOT GM! The U-joints are common GM parts though, and the wheel pattern (5 x 4.75") is common full size GM. I made some notes in my last post about wheels and tread, read if interested in using a Jag axle! I spent $100 on a decent looking axle in a pick-n-pull yard. One caliper was frozen solid, had to be replaced, the grease fill cap had come off one side and caused bearings to go bad in the outer carrier so I replaced bearings in BOTH outer carriers along with seals, new rotors were needed, and I replaced all seals in the differential as they are known to go bad with time due to heat from the brakes and exhaust, which passes very close to the diff in a stock Jag. I also had to replace the gears. I spent another $800 on the axle and did most of the work myself ($250 was spent on labor to set up the new gears and press off/on the outer hub bearings). you can usually find them in good working condition for around $500, but I'd still replace the seals while the thing was out. The entire axle has to come out and apart to replace the diff seals and brake rotors.
Old 06-01-2003, 06:35 PM
Post
I am also installing a Jag rear end in my project Pinto. I have been looking for a company that might make a kit with a top mount and lower arms. I am looking for something like a cut fit kit. Is there such an animal or do I have to scratch build everything?
Old 04-20-2006, 05:39 PM
Wiki Edits: 27
jag rear end
California custom roadsters in southern california sells a set of T bucket plans for a jag rear end for $ 5. a real bargain just make the crosmenber wider to fit your project.
Old 05-25-2006, 11:33 AM
Jag IRS
Hi everyone,
I'm new to your site and stumbled onto some IRS questions. CWI inc. has been manufacturing IRS for nearly 25 years, we do tons of Jag rears and can build anything you would like. We also have a 9" Ford IRS and a Speedway quick change. We have been stepping up our advertising and are now in Good Guys mag, Street Rodder, and Drive. We are currently working on some actual bolt in suspensions for the muscle car market and we are also making a billet hub which has outboard brakes and an internal expanding E- brake. We are Wilwood dealers and Aldan Shock dealer and have many kits for Jag. We do complete rebuilds of customer rears or can supply any part from the Jag. I'd be happy to answer any questions anyone has and you can check out our website ****
Thanks,
Eric
From the MODERATOR ...
Eric ... I understand you are new to our forum and I want to WELCOME YOU ... Your knowledge and help is most welcome but we do not allow advertising, or links to commercial businesses .
Deuce ... Moderator
Last edited by Deuce; 04-16-2007 at 05:10 AM. Reason: Violation of guidelines. Please see: general board guidelines.
