Indepenece for a 32 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2005, 02:17 PM
Hi ,I am buildind a 32 ford roadster and want a ifs.Ideally I would like something like the Kugel components ifs but as it becomes a bit expensive in New Zealand I want to build my own. If anyone one has plans alond the same lines as Kugel please let me know. Any help at all would be great at this stage.
Cheers
Old 12-10-2005, 06:59 PM
jalopy45's Avatar
I believe Gerry used a Jaguar for the base design so you might look at the E-type and saloon front ends for pieces or a complete swap. The drear ends work well too.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 12-10-2005, 07:42 PM
As a Moderator here, I would like to WELCOME YOU HERE.....
If you are going to go without fenders, A IFS can work on a 32 Ford. With fenders...the fenders interferes with the PROPER placement of the upper A arms. They should be equal length to the lower A arms and be parallel.
See how the A arms are NOT level with the ground and how much angle is on the upper A arm ? in the photo. This is the problem with IFS on Model A's and 32's. You know the camber HAS to be all over the place when the suspension moves.
I read in another post you did not have the 32 frame dimensions......so NOW you do.
Old 12-10-2005, 08:07 PM
This is how it should be......to be correct engineering wise....but this is NOT a 32 chassis. See how the upper A arm would NOT allow the fender to be in place ? See how the A arms are equal length ? They are also parallel....to the ground.
The photo abpve is a correctly done IFS ........and by Jerry Kugel....and he sells some IFS parts separately.
There may be a vehicle in you country that could be adapted....
Old 12-12-2005, 12:11 AM
Thanks for you help, i thought that parallel would be better, but all the pictures I have seen all show the top arm shorter and heading down to the chassis.
'32 ford question bonuts Body - Exterior 9 02-18-2009 03:23 PM
Parallel leaf rear suspension in a '32 Ford deuceguy32 Suspension - Brakes - Steering 2 09-29-2003 08:44 AM
picture's 32 ford pkup wizard1932 Hotrodders' Lounge 0 09-24-2002 05:08 PM
32 ford drip rails andy223 Body - Exterior 2 04-21-2002 04:24 PM
32 Ford Coupe Body LoTempio Body - Exterior 4 01-29-2002 12:03 PM
