Indepentent rear end on an F-1
I would love to have some more advise, or would love to talk to someone that has done this before. I have a F-1 1/2 ton and would like to put and independent rear end under it. I know I would have to beef up the springs, and modify the mounting brackets, but does anyone have any other advise. Is this a good way to go?
thanks
As a matter of fact the rear end I am planning on using is from a 96 ford thunderbird. I hope this will be an easy fit. The front end I used a mustang front clip. Worked out really well. Thanks for the e-mail
F1, help
More than glad to be of help. You should study the mounting on the T Bird. and copy same. I would block and level the frame and use the running board brackets as a reference for ride height and stance. I plan on using the rubber mounts that came with the rear end.
Is your rear end Disk brake? Also some of the Birds have a metric bolt pattern. I have also found a 1991 Super Coupe that has 5 on 4 1/2. What are you planning for an engine? |
rear end
Thanks again for the help. The rear end is sitting under the frame now, and looks like a pretty good fit. The dimensions are turning out very well. Were looking and making some mounting brackets, and using the rubber groments to mount the rear end. Looking at it right now the height looks to be perfect, however without the engine in it, the front is sitting high, so its hard to tell for sure. The engine I plan on using is a 4.6 liter, also out of the thunderbird. Only has 40,000 original miles. I think that it will make that truck scream. After the rear end is close, its time to chop the top 2". Thanks for the help again.
Sounds good. I have a friend with a 52 F1, with a 4.6 with a AOD trans. Really nice swap. I also have a friend that is installing one in his 56, with a 5 speed. If the gas cost ever comes down I plan on using a 6.8 V10.with a 5 speed. It is not hard to put 300 miles on a weekend around here for Rod Runs. but I don't have to tell you about that. What part of Utah are you from?
Irs
Thought I'd join the conversation. I am using a Ford IRS in my project which is a 1950 Studebaker Champion. Power comes by way of BB Cadillac channeled through a 4L80E transmission. Saw that Trowley is in Utah - which is where I am.
| Thump Thump in rear end?? | HotRodMan | Suspension - Brakes - Steering | 7 | 01-24-2007 06:09 PM |
| 1975 8.5 rear end | camino_man | Transmission - Rearend | 6 | 09-18-2004 05:32 AM |
| Rear End Change | black66 | Transmission - Rearend | 4 | 01-28-2004 09:21 AM |
| Important rear end mounting question | 71gtx | Transmission - Rearend | 2 | 01-04-2004 06:05 PM |
| Ford 7.5" Rear End Traction-Loc Install | nightrain_rod | Transmission - Rearend | 2 | 12-30-2003 06:38 PM |
