Early Hemi rocker shafts Hotrodders.com Free Speech Parts Auctions
Bid on a part, or auction one off -- help us defend against a frivolous lawsuit, and protect free speech online.
Click here for details.
Parts currently up for auction: 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, Early Hemi rocker shafts, "Power Rods" billet air cleaner top.
Model A Ford headlights
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-25-2006, 03:11 PM
37 Dodge 37 Dodge is offline
Indexing plugs
When you index a plug, does the electrode aim toward the exhaust valve or the intake valve ??? Thanks, any pictures?
Old 01-25-2006, 03:17 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Moderator
 Henry Highrise's barnstar
Wiki Edits: 4
re: Indexing plugs
I have never done it...but I would say the intake valve.
Old 01-25-2006, 03:22 PM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
re: Indexing plugs
Save your time and energy it isn't worth the effort.
Old 01-25-2006, 03:24 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Moderator
re: Indexing plugs
I agree, isn't worth the time and effort, unless your running a funny car or a top fueler.
Vince
Old 02-07-2006, 09:32 PM
gearhead56 gearhead56 is offline
Indexing Plugs
i have run into some people who say it doesnt mean anything o go through the hassle of indexing your plugs , well on the dyno i have seen horsepower gains not much but two or three horses. so if you are looking for a good qualifying time or you just need that extra push it is there , wether or not you are that perticular or have nothing better to do it does make a differance.
Old 02-07-2006, 09:46 PM
re: Indexing plugs
I won't argue that in "some" cases it makes a "slight"difference. I bet those dynoed engines had dome pistone or pop ups. Am I right? With a flat top or a dish piston I doubt you will see any difference at all. One things for sure it doesn;t hurt to try it. You will not see or feel a difference from driving the car (IMO).
Royce
Old 02-07-2006, 10:08 PM
indexing plugs
well actually the engines im talking about where flat top pistons.They where circle track motors. Ihave seen bigger gains on domed tight clearence piston to head engines as much as 5 or 6 horses. when your looking for the littlest edge hard work is required always . Its like the guys who use to argue that crasnkcase pressure doesnt rob horsepower now the top nascar teams run vacume pumps . i built a lot of restrictor plate engines where every horsepower counted , stuff like that gives you that edge .
Old 02-07-2006, 10:23 PM
re: Indexing plugs
I agree. On your typical street car or street/strip car you are not going to see any difference in performance. 99.9% of them are not running at maximum efficientcy and the time spent indexing plugs could be spent getting the carb spot on or the timing curve right, etc... Now for class racing where the competition is VERY tight then every little things makes a difference from oil weight to plug indexing, no arguement from me on that. I think you have to determine the type of car we are working with and the goals. I am not going to index the plugs on my wifes daily driver, but if I was running a TF dragster I might think about it.
I figured the gains would be larger for dome pistons, but I am shocked you saw that much difference with flat tops.
Royce
Old 02-07-2006, 10:25 PM
kringold's Avatar
kringold kringold is offline
ATA Welding Technology
 kringold's barnstar
Say what?
Now what was the question? Is it worth the time, or which way do the plugs face? Anyways I haven't tried it YET, however I have read an article on it somewhere and am interested in trying it. IF, I remember right, the article stated that they are pointed toward the center of the cylinder, and not towards either intake or the exhaust valves. But I may/probably am/could be wrong. I'm interested in the answer to the original question also.
Old 02-07-2006, 10:36 PM
re: Indexing plugs
"Generally speaking, the idea of indexing is to position the spark plug so that its gap is facing the center of the cylinder, angled slightly toward the exhaust valve—the most common arrangement. (Some engines work better with other gap locations.) This is important because, as the piston approaches TDC, the air/fuel charge is being compressed. The charge or "mixture" is being forced toward the area of the spark plug—and normally, the exhaust valve. The true speed of this force inside the combustion chamber is extremely fast. Some experts speculate that it surpasses supersonic speeds.
Because of this, the spark generated from the plug should be in a "position" to create the best possible flame front. Looking at a typical side-gap spark plug, you'll note that the electrode can actually block the flame process. On the other hand, if the electrode gap faces the on-rushing air/fuel charge, it stands a much better chance of igniting a flame front."
Does that answer the "original" question?
Royce
Old 02-08-2006, 01:39 AM
GoneNova/406's Avatar
GoneNova/406 GoneNova/406 is offline
re: Indexing plugs
depending on the heads you have the plug will point whre ever it points in those particular heads.when you inex them you want open side of the plug to face the combustion chamber or where the explosion occurs to get the best bang.you can't change where the plugs point.not easily.
Old 02-08-2006, 07:02 AM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
Spark Plug indexing
There is not a set "This is the Best" way to index a spark plug. Every engine is going to be a little different. Too many variables, combustion chamber shape, piston style, quench area, flame speed, swirl, etc. Normally you'll want to start out as stated with the open side of the plug towards the open area of the chamber. Then you'd experiment from there. Doubt you will see any "Seat of the Pants" feel, but you may be able to increase your burn rate which can help your fuel economy.
Old 02-08-2006, 08:45 AM
kringold's Avatar
 kringold's barnstar
re: Indexing plugs
Royce
Yes and thank you very much.
Old 02-08-2006, 09:01 AM
k-star k-star is online now
Jesus saves
plugs
Lots of good info so far,, some more thoughts...
Indexing plugs started as a way to keep the domes of pistons from smashing the ground strap off of the plug. Some engines will require you to do this or else, no more plug ends!!!!!
As far as power goes, It's like most everything else in hot-rodding it will depend on the combo if results are seen from indexing... I would start out with the opening facing the exhaust valve....
Keith
K-Star Automotive
Performance Engines
The crash was easy: rehab is killing me-"John Force"
Old 02-08-2006, 09:04 AM
Spark Plug indexing
One more note we've also "indexed" plugs to control their depth. This has been done on some higher end race engines per cylinder to change the burn rate to compensate for richer or leaner cylinders.
Back to top
This discussion has been added to the Engine Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Indexing plugs"
Method to determine carburator CFM? jpd37 Engine 68 10-29-2006 09:55 AM
LS1 Spark Plugs dusterbd Engine 0 10-14-2005 10:08 PM
Rant: Bosch Plugs Cost me $300.00 Rolm Engine 7 07-22-2004 09:50 PM
Indexing spark plugs Rodrunner Engine 3 05-20-2003 03:26 AM
Plugs DoubleVision Engine 5 05-06-2003 03:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
