Induction ?? On A 355hp Crate Motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 08:10 PM
Hi guys, I need your help here. I finally found the time to work on one of my own projects . 1988 chevy phantom duelley,it's been in limbo for about 8 yrs now. I have a zz4 355 hp crate motor sittin in my shop (still in crate) beggin to go in this truck. I bought this thing what seems like a hundred years ago for a great $$. In the past i always went wayyy overboard with my projects and they always took too long or cost way too much or both.
My questions are can I run the stock tb with this motor? Is there a manifold that will work? If not what are my options. I really dont want to spend the$$ on a new inj. system.
I would like to keep the computer, o2 sens ect... I plan on running headers+ dual cats. I'm not looking for a drag truck so I'm not trying to wring every bit of hp out of this motor.
What are your thoughts. thanks dave
Old 03-23-2005, 12:10 AM
Siggy_Freud's Avatar
What was the stock TB on? If it was a 350 you should have no problems. A custom chip programmed per your setup might benefit you but it wont be nessesary. Most manifold makers make a manifold (tounge twister) for the TBI in a variety of power ranges.
Old 03-23-2005, 08:51 AM
Siggy the motor in it now is the stock 5.7 350. The new motor has aluminum heads not sure of the bolt pattern for the manifold. I was hoping that I could find an intake that will go on the new heads and the stock TB will bolt on. I was also concerned the stock TB would be too restrictive or not deliver enough fuel. If this is going to be tough I decided a carb and no computer will have to do
If the stock tbi will bolt on I was planning on having a chip burned for it.
thanks let me know if you have any other ideas.
dave
514 CU.IN FORD CRATE MOTOR? hotrodders4christ Engine 2 05-02-2006 08:52 AM
Change lifters on crate motor??? leastbay Engine 3 12-28-2004 08:30 PM
Chev crate motor on 87 octane? Blackdog Engine 5 12-28-2004 12:08 AM
gm crate motor ?,s waynedawg Engine 2 12-26-2004 06:27 PM
385 fast burn crate motor camaroconvert69 Hotrodders' Lounge 9 06-15-2004 10:03 PM
