Lined blocks
I wanted to use cement block lined with more brick inside.Also get sheet metal liner and exterior from scrap yard,may even have a large metal locker or a few smaller ones to reconfigure the oven wool between block and inner material.The oven elements to heat a metal plate(heat sink).That is if you find the room to do it this way.If not on your power bill you can get a portable meter and keep it going. Ps Can use blocks to raise or lower heat source and take up space for smaller parts. Keep blocks running along ground and not up.Use re-bar where you can.PS i don't have the space just yet.But may have soon
