Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - inexpensive filter/dryer
  #23 (permalink)
Old 01-16-2011, 03:49 PM
Silverback's Avatar
Silverback Silverback is offline
Boost Retard
I run my regulator as close to the hoses that I'm using as possible, more pressure in the lines means more delivery. Even then usually I keep it set at 90psi, and most things that need less also need a fairly high volume, like a spray gun or blast cabinet, so I put a regulator right at the inlet to whatever it is...
