Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - inexpensive filter/dryer
  #40 (permalink)
Old 01-18-2011, 10:29 PM
001mustang's Avatar
001mustang 001mustang is offline
Originally Posted by DadTruck
001mustang
you say on "most days"
does that mean on "some" days you are willing to put up with defective painted surfaces, issues with sand clumping when blasting,, due to moisture,,,
if you are putting in an effective air system, you will spend a few bucks, for a nickel more, you have moisture issues under control, forever.
again, its just me, I will nickel and dime a lot of things,, painting, including surface prep, blasting is not one of them,, its either perfect, or its not,
there is nothing in between.
I only paint on days when ambient temp is in proper range.
Haven't tried to paint car on rainy day recently.
I have sharpe desiccant system but don't use it all the time.
Typically valve it in for CC; my media lasts a long time.
I was thinking I wasted money on desiccant system since most of the water drops out in long cooling line.
Maybe I should use media when priming, etc. Couldn't hurt.
