-   -   INFO FOR 33 WILLYS (http://www.hotrodders.com/forum/info-33-willys-11962.html)
DossWallace 07-20-2002 02:07 PM
INFO FOR 33 WILLYS
BUILDING A 33 WILLYS COUPE. HAVE BODY AND PRO STREET TYPE FRAME. PLAN TO USE STRAIGHT AXLE FRONT END AND FOUR BAR SUSPENDED REAR END. WOULD LIKE TO KNOW IF ANYONE OUT THERE HAPPENS TO KNOW WHAT THE STOCK HUB FACE TO HUB FACE DIMENSIONS ARE FOR THE FRONT AND REAR OF A 33 WILLYS? YOUR HELP IS APPRECIATED.
willys36@aol.com 07-20-2002 06:13 PM
I run a stock front axle on my '36 (identical to '33 except different hood sheetmetal). Distance between kingpins is 46". I run Torino disk brakes & hubs so don't know stock dimensions but mine are 52" wheel surface to wheel surface. I run a narrowed '56 rear end but rear is likely the same as front on a stocker; car is exactly the same width @ the front and rear fenders.
