Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - INFO FOR 33 WILLYS
Old 07-20-2002, 06:13 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
I run a stock front axle on my '36 (identical to '33 except different hood sheetmetal). Distance between kingpins is 46". I run Torino disk brakes & hubs so don't know stock dimensions but mine are 52" wheel surface to wheel surface. I run a narrowed '56 rear end but rear is likely the same as front on a stocker; car is exactly the same width @ the front and rear fenders.
