Info on big block swaps for C/K trucks out there? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2006, 08:18 PM
New Member
I am wanting to swap a big block in my 1500 which is currently a 350, the kicker is keeping all accessories. Although I have never heard of this for the 3/4 ton outside of the SS, I am thinking there cannot be too much to it with the larger frame trucks have factory optioned big blocks. Anyone care to share? Would be nice if I could just pull a long block with all accessories from an optioned pick up, but me thinks that would be just way to easy.
Mike
Old 08-04-2006, 05:17 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Mike
How many accessories do you have? A/C should be the same bracket (at the rear) for the same year truck. I'm not really sure when GM started using an aluminium "cluster bracket" I know both my old '93 and my current '97 have the brackets bolted to the block and heads. If the bolt holes line up, it would be a direct fit from a SB to a BB. Otherwise, you got 2 choices. Go aftermarket for brackets, or fab your own. Deep pockets, or a solid afternoon at a salvage yard, you choose.
In a while, Chet.
427 Big block blew up, need a few suggestions. esears Engine 17 03-12-2007 08:18 AM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
small block or big block southrncuz1816 Engine 16 03-19-2006 07:40 PM
Big block to small block 69 chevelle SS Engine 2 08-31-2003 12:06 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
