Info on engine swap req'd - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2008, 09:21 AM
Hey Gang...
I just bought a really nice 1941 Plymouth 2D Coupe. It has the original 201.3ci flathead 6, and 3-on-the-tree manual. I have some questions that maybe some of you guys can answer...
1. I want to Hot Rod this gem. I am thinking that a 318 or 360 would be just right for it. Is there an available motor mount conversion kit for this conversion, or do I need to just get a set of correct V8 mounts and weld them on (...after figuring geometry and stuff...)?
2. For anyone who has done such a conversion, are there clearance isses with regards to headers, steering box/components, frame rails, etc?
3. I would like to use the 3 speed trans that's in the car...soooo...a.) Can the tranny take the added power of a V8 (provided that I am not beating on it)? b.) Is there a bell housing available that will allow me to bolt this trans to the V8? BTW, can anyone advise which tranny this car would have? c.) If the original tranny is not recommended, what other trannys would you recommend (prefer manual over auto) that wouldn't require much body/floorboard/frame modifications?
4. The stock rear axle and suspension look pretty beefy. Will these parts require any modifcation for the swap? Keeping in mind that I am NOT looking to build a stop light bandit or race car...just a nice cruising car with a lumpy cam and mean exhaust tone.
5. Any other issues or tips would be greatly appreciated!
I think that's it for now. I look forward to hearing some ideas.
Thanks!!
Ty
Old 10-27-2008, 10:54 AM
Wiki Edits: 49
When it comes to motor mounts you'll probably have to do some fabrication. The stuff on THIS site should be helpful.
If you upgrade the front suspension and steering chances are a 318 or 360 will not create significant interference especially if you use block hugger headers.
DO NOT attempt to use the stock trans or rear end. They were made to handle 100 hp and they're 60 years old. They will simply not handle the torque of a modern V8 and be reliable. There are plenty of standard and automatic trans that will work with the "A" block V8's and there are also a gazillion rear ends to choose from. Don't do a half way job. If you're going to put a V8 in there then upgrade the rest of the drive train, suspension and BRAKES.
Old 10-27-2008, 04:01 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
The trans I would use is the 4 speed older Mopar that uses the muscle car type trans but has OD in 4th. They should be easy to find from mid 70s up.
I'd never try to use the old trans, plus having to deal with making an adapter would be crazy money & time.
Scrap the rear. There are tons of cheap rears around and you can find online measurement charts to find the right width....after you choose a wheel style & offset. Lots of beginners don't understand that you need to plan the rear width AFTER picking wheels.
Old 10-28-2008, 12:24 AM
41 coupe
Wow! You have brought back some great memories. My very first car was a grey 41 coupe that my Dad had bought for a cousin of mine who was living with us at the time. He said no thanks so at the ripe old age of 14 I got my first car. A friend and I rebuilt the six at his fathers machine shop in downtown L A and the only chrome was a brand new air cleaner on my carb.I dropped the front end three inches and my Dad and I recovered the inside door panels with grey naughahide [sp] . I was driving at 15 illegally and got my licence at 15 1/2 and drove the heck out of my car. Lions to Ontario and San fernando to bakersfield now thoes were the days. So thank you very much . Pops.
Old 10-28-2008, 12:44 AM
SSedan64's Avatar
Here's a few sites of rearend widths for a donor rear.
http://carnut.com/specs/rear.html
http://50chevy.freeservers.com/Suspension_Widths.html
Old 10-28-2008, 02:59 AM
techinspector1's Avatar
Wiki Edits: 326
Follow the advice given here about the rear. I popped a tooth off the spider gear with the stock 6-banger flathead in my '47 Dodge.
Old 10-28-2008, 12:38 PM
OHD's Avatar
OHD OHD is offline
Choose your rear
mock it up with the wheels you are going to use and
cut it to fit... (housing ends and axles) while rebuilding it.
seems every time I have tried to get one that fit I had to do stepts 1-3 anyway..
Old 10-31-2008, 04:08 PM
Wow...thanks for all the tips. I currently have a line in a 273ci and 4 speed manual trans. Should work well. What about front end issues? Will I need to relocate the steering box and make any other front end mods? Keeping in mind that I want to keep the car as stock looking as possible.
Thanks...your help is greatly appreciated!
Ty
Old 10-31-2008, 04:28 PM
Wiki Edits: 326
Ty
Use the radiator, shroud, fan and all other cooling parts from the 273 donor. No room? MAKE ROOM.
The motor/trans can be moved toward the passenger side of the car as far as you want to to miss the steering box. Just keep the centerline of the crank perpendicular to the centerline of the rear axle.
Old 10-31-2008, 05:22 PM
You should give serious thought to upgrading the front brakes to discs. There are kits available to do that with these cars. The stock brakes were notoriously poor. Discs would be much safer.
Old 11-06-2008, 09:37 AM
Hey gang...
Thanks again for all the info. I DID get the rebuilt 273, 4 barrel intake with Carter AFB, A833 4 speed and lots of other bits from a guy I know. I just need a clutch and flywheel, bell housing, rad and the usual little bits and pieces.
I am going to follow your advice and swap the axle too. I was going to just leave it, and "go easy on it" when driving, but I figured if it breaks next summer when I want to drive the car, then it's out of commission. Soooo...I'll just do the swap when I have the car apart anyways.
Other plans for the car include a set of chrome Smoothie wheels and wide white wall RADIAL tires in a 7 or 8" width. Give the car a nice stance.
I'll get some pics posted when I can...
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
Engine Swap Help!!! crazytown Engine 7 09-04-2008 08:15 PM
SF oil???? n-gin Engine 6 07-09-2008 02:37 PM
87 s10 2.8 v6 to 3.4 v6 crate engine swap info needed 87sdime4x4 Engine 1 07-23-2006 08:15 PM
