Info on Ford 300 I6... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2004, 04:33 PM
Mike_82's Avatar
Hi. my friend just got a ford f-150 2wd with a 300 CI I6. he wants to know what a safe rev limit would be, what the factory HP/TQ ratings are, and what kind of fuel milage should he expect? Thanks.
Old 06-09-2004, 06:34 PM
Fordcrazy's Avatar
4000 rpm is about the max you would safely take it. fuel mileage is fairly decent for a truck with a six depending on gear ratio and what tranny it has. the six was only rated at around 150 hp in the 70's and it might have gone up since then
Old 06-09-2004, 06:59 PM
camino75080's Avatar
What does this button do?
I own a '88 F-150 with the 300 I-6. I have done some research on the motor and found that mine should have about 180 ft/lbs of torque and about 150 HP, not that great. As far as mileage goes with a 5-speed i get between 9 and 14 miles to the gallon. I dont agree with Fordcrazy as for a 4000 RPM as the limit, I'd say about 5000 RPM.
Old 06-12-2004, 08:02 PM
New Member
I have owned a 1988 Ford F250 4x4 with the 300 inline 6 with 5 speed. Most of the year I get 13-16 mpg, but in the spring when it warms up above 70 degrees, for about a month, I get at least 16 and as much as 20 mpg! This has happened every year, and I have never understood why. By the way, it has about 320,000 miles on it, has never been opened up, and still gets about 2500 miles before it uses a quart of oil! And most of that leaks out of a bad valve cover gasket.
Old 06-13-2004, 12:40 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
I drove an 89 F150 2wd King cab for about 5 years. It had a 3.08 rear ratio and a 5 speed. On a cross country trip, unloaded, it managed a rather disappointing 17 mpg.
It would rev to 4000, but all the power was in by about 3700. No point in revving it anymore.
A good solid working truck, it would happily pull just about anything you'd sensibly want a 1/2 ton truck loaded with and then some. But for stoplight to stoplight fun, be prepared to be outrun by almost everything except semi trucks.
Old 07-05-2004, 02:32 AM
New Member
Re: Info on Ford 300 I6...
is it an EFI, or carb'd version?
i have a '93 SWB reg. cab with the E40D auto and i get 20 MPG going 72mph on highway trips
in town i get between 12-15 MPG
the EFI engines make about 145 HP @ 3500 and 260 ft-lbs. @ 2000-2800, the carb'd versions lost about 30 HP, and about 25-30 ft-lbs
if it's a stock engine, don't even worry about the rev limit, the head doesn't breath well enough to reach it, but i will agree that it's about 5000 RPMs
