Info on small block ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2012, 03:05 PM
Aussies here have a 32 ford roadster,302 Windsor,small cam,edelbrock e street heads,c10 auto, 3.1 gears,runs on straight LPG gas,weighs 990kgs,compression ratio unknown,it has no get and go,unless you downchange and get it revving,can you guys suggest anything,or better to go new crate engine or dart block, dart heads etc,unsure of cubes, 331, 347,336, any suggestions would be appreciated thanx Peter.
Old 03-01-2012, 03:56 PM
DoubleVision's Avatar
I don't think you need a new engine Pete, I think it needs to be tuned in correctly. The parts you have on your 302 are plenty enough for it to have good power as I've seen many a 302 be a strong street contender. What size ports do the heads have? How tall are the rear tires? What is the spark timing set at? Off the top of my head one thing I see wrong is it needs gears, 3:1 ratio is rather poor, and if the tires have any height to them this makes it even worse. If you still want to replace the 302 there's no question the next step would be a 351 Windsor. I don't know much about LP gas, however I do know you have to add far more of it as the compression ratio goes up.
Old 03-01-2012, 04:13 PM
32 specs
pirelli p300,235/75/15 tyres, valve size 1.90/1.60
Small block ford genewa1 Hotrodding Basics 10 12-06-2012 03:20 PM
ford small block in 48 ford pu what headers hemivolvo Engine 0 07-20-2007 04:02 PM
420 cu. small block info hause Engine 0 03-04-2006 06:04 PM
Need Info On 72 Small Block Chevy impala59 Engine 5 10-01-2003 05:11 PM
need info on small block chevys engine-rookie Engine 1 05-03-2003 08:48 PM
